Smoking. Smoking. Smoking
Old Sep 29, 2004 | 09:36 AM
plymouth383's Avatar
OK, i have a 1988 nissan maxima, with 151k miles, when driving down the road i get a big cloud of white smoke, now heres the catch, sometimes only sometimes it smokes. even at idle it sometimes smokes. im thinking its burning oil because i go through alot in it, and sometimes when driving along normally it shudders. The weird thing is i just took it to nissan for the injector recall and it never did anything of this sort until after i got it back from them. With the smoking i took out the plugs but there is no oil on any of them, and compression is 120 all around, so i dont know why it would be smoking from the exhaust. I just need some help on this one. Thanks
Old Sep 29, 2004 | 09:54 AM
turboast4's Avatar
Blue smoke = burning oil
Black smoke = running rich
White smoke = burning coolant
Old Sep 29, 2004 | 10:40 AM
Drjmaxx88's Avatar
Check coolant level. Is it low?
Check timing.
Does it smell when the car is smoking?
Old Sep 29, 2004 | 12:27 PM
yes it does smell pretty bad, but the coolant level is fine, what would be the cause of coolant though. like i said i checked compression in everything. Thanks
Old Sep 29, 2004 | 01:04 PM
maximase86's Avatar
I love lamp.
Ack! 120psi each cylinder? That is really low to me. Obvious oil consumption. Have you check the oil to see if it looks like a chocolate shake consistency? Unfortunately, I hate to say this....but your motor might be on it's way out.
S
Old Sep 29, 2004 | 02:26 PM
Drjmaxx88's Avatar
It sounds like a blown head gasket.
Check the oil how does it look.
Whatever you do don't add any aditives to the oil. Nothing that will stop the leak, or boost compression. They will make things worse.
Old Sep 29, 2004 | 06:41 PM
Niku-Sama's Avatar
S
to add to this...
if milkshakeish: is it sparkly?
Old Sep 29, 2004 | 07:57 PM
broncoguy's Avatar
I am having the same problem with my 3rd gen after working on the injectors. I am leaning towards a gasket problem in the intake area, since the upper intake has to be removed in order to get to the injectors. The other thing people are suggesting is that there may be a leaking injector or one that isn't sealed right and it's dumping too much gas in.
If yours wasn't doing it until after you got it back, you really need to take it back to the dealer and have them fix it. And if you do, let me know what the fix was!
homewrecker
Sep 24, 2015 07:01 PM
ballerchris510
Sep 10, 2015 09:35 PM
FlaMark
Aug 21, 2015 11:06 AM
Balkins
Aug 12, 2015 06:39 AM
