Runs crappy in higher gears
Old Mar 1, 2005 | 05:02 AM
kathy's Avatar
My car starts and runs good in lower gears.The problem is, the warmer it gets the worse it runs. When i accelerate to 4th gear, it runs crappy. There's no pickup at all and I seem to lose speed and power. The whole motor feels like it's shuddering. Sounds ok in neutral. Any ideas?
Old Mar 1, 2005 | 06:12 AM
MaxWgn's Avatar
5-speed or slush-box?
Old Mar 1, 2005 | 06:44 AM
kathy's Avatar
It's a 5 speed.
Old Mar 1, 2005 | 07:14 AM
cardana24's Avatar
Blown
I know sometimes when you have a spark plug wire arching it will act this way or if the distributor cap is cracked. It will only miss when under load. I would crank the car at night and manually rev it while you are under the hood and see if you see any arching. See if you can make it run crappy by just reving it from under the hood. I say to do this at night, so it will be dark and you can see if you are loosing spark anywhere. Also make sure the wire going to your coil is on tight...my car ran similar to what you are describing when the coil wire was not hooked up well. Goodluck.
-Carson
Old Mar 1, 2005 | 04:38 PM
maximase86's Avatar
I love lamp.
Check for codes definately. Could be a bad CHTS, maybe your timing is not right..
S
Old Mar 1, 2005 | 07:21 PM
blackmaxima88's Avatar
^^^ what he said... it sounds like an ignition issue.. either a bad wire or the timing's probably off
Old Mar 1, 2005 | 10:27 PM
maximase86's Avatar
I love lamp.
Also check the coil....that is a common thing the motor does with a bad coil. As it heats up, the coil starts getting a sporatic charge.
S
Old Mar 2, 2005 | 05:37 PM
kathy's Avatar
Everything seems to be tight, no arching. I'll get a hold of a timing light and pull codes tomorrow. Thx guys.....
Old Mar 14, 2005 | 05:25 AM
kathy's Avatar
Well, i said it wasn't arching but a friend listened to it and got shocked when he touched the distributer cap. The #2 wire was shocky. Replaced the cap , button and wires. Runs real good now, thx.
Old Mar 24, 2005 | 07:30 PM
130t_driver's Avatar
Get A Better Car
Old Mar 25, 2005 | 07:24 PM
maximase86's Avatar
I love lamp.
Hmmm....I wonder if I should trust the advice of a guy that drives ugly crap. :P
S
Old Mar 26, 2005 | 11:57 AM
kathy's Avatar
I don't want a "better" car. I happen to like the body style of this one. They just don't make cars like they used to.
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
