87 fuel system recall
Old Mar 2, 2005 | 04:06 PM
87MaximaGuy's Avatar
ok i was told that the fuel system on the 87 maxima was recalled, so i called up the local dealer and they say since the recall was over ten yrs ago they cant help me, has anyone gotten this recall done past the ten yr mark?
Old Mar 2, 2005 | 05:36 PM
kathy's Avatar
Had mine done about 3 months ago, no problems at all. New injectors, rails , fuel filter and hoses. They had the car about 3 days, since they had to order the parts. Didn't cost me a penny.
Old Mar 3, 2005 | 05:22 AM
cardana24's Avatar
Blown
that's a lie, the recall is still open
Old Mar 3, 2005 | 06:30 AM
MaxWgn's Avatar
Yeah, either try another dealership, or try contacting Nissan directly...
Old Mar 22, 2005 | 05:19 PM
Gquack60's Avatar
What problems is the recall addressing?
Old Mar 22, 2005 | 05:52 PM
jos's Avatar
jos
Recall addresses leaky injectors - smell of gas, especially in cold weather.
Old Mar 22, 2005 | 07:04 PM
Gquack60's Avatar
running rich, and a little rough?
Old Mar 24, 2005 | 04:59 AM
kathy's Avatar
Take advantage of it and get yours done.
Old Mar 24, 2005 | 02:32 PM
Niku-Sama's Avatar
any way to tell if its already been done?
Old Mar 25, 2005 | 05:02 AM
cardana24's Avatar
Blown
you can ask the dealer and they can check on your VIN number, or you can call 1-800-NISSAN1 and they can check by using your VIN number as well
Old Mar 25, 2005 | 08:35 AM
keith_u's Avatar
I called nissan about mine and not all of the 87's were affected by this they told me that mine wasn't but if it was they would have set it up with the dealer nearest to me to have it done.just call nissan and don't mess with the dealership moxt of them are stupid and have no clue what there talking about
Old Apr 4, 2005 | 02:40 PM
Zeke21's Avatar
what if you have had your motor replaced. is there any way to tell if it had been done on the new motor?
Old Apr 5, 2005 | 05:39 AM
cardana24's Avatar
Blown
not anyway that I know(that are legal anyway)....I am not sure if the injectors have different color caps or not.
Old Apr 6, 2005 | 08:22 PM
seanagins's Avatar
not all 87's were affected. mine wasn't
Old Apr 8, 2005 | 02:55 AM
Niku-Sama's Avatar
yea i already know the dealer here is a flaming cake-***, i try to deal with them as little as possible
Old Apr 10, 2005 | 08:31 PM
smj999smj's Avatar
One way you can usually tell is to look at the injector harness. Not all, but the majority of the recalls has fuel injector subharness kits installed. This kit used the middle injector harness wires only and capped off the front and rear injectors on each side. This was possible as each bank of injectors fires at the same time. The new subharnesses were also identified by yellow tape stripes.
Old Apr 10, 2005 | 09:20 PM
Niku-Sama's Avatar
the only thing i rember opf the top end fuel system i rember are the hoses leading from the fuel rail to the injectors them selves were in almost brandnew condition with yellow fastners....but that does not say much because the cylinderwalls looked the same aswell as a bunch on the parts
Old Apr 15, 2005 | 02:27 PM
ArchPhoenix's Avatar
My 86 Maxima seems to have a problem with the fuel intake system (I think).
Everytime I get out of the car I smell gas, and it runs pretty choppy when I'm not giving it gas, just simply going in reverse or drifting.
By any chance could the recall effect the 86 as well as the 87?
My 86 has 106,000 miles, and was sitting for 4 years. (Just a little FYI)
Old Apr 15, 2005 | 10:26 PM
Niku-Sama's Avatar
ok one thing i noticed about my car is that the gas cap is harldy ever put on correctly...which is freaking dumb, they dont know how to screw a gas cap on at a gas station?
oh and for those of you who dont know, i do know how to put a gas cap on how ever in oregon its the law (es la ley or how ever) that gas attendants pump the gass and not the drivers under some circumstances you can pump it your self (like a custom or classic)....how ever any one who applies to be a gas attendant only needs a highschool diploma and THATS IT...which in it self is even more dumb
Old Apr 16, 2005 | 08:25 PM
lol, what else would someone who pumps your gas need to major in? You think some guy with a GED in networking would pump gas, or better yet someone with a bachleors degree in engineering decide he wants to become a slave to his occupation?
I have to diagree with you there, although it seems like stupid people are breeding, anything over a high school deploma would never slump to the level of pumping your gas for you. It's just wrong.
Old Apr 17, 2005 | 09:10 AM
fatboyslim86440's Avatar
what are the years on this recall
Old Apr 18, 2005 | 05:07 AM
cardana24's Avatar
Blown
85-88............just check your VIN
Old Apr 18, 2005 | 07:45 PM
awesome, ty, I believe I'll call 1-800-NISSAN-1 tomorrow.
Old Apr 18, 2005 | 09:16 PM
1madmax's Avatar
i had an 85 and an 87 and had both serviced. there was a recall due to the changing chemical components in fuel and how they were eating the seals in the injectors. my 85 caught on fire. lots of fun. luckily i was parked in front of a dry cleaner and was able to borrow their fire extinguisher before the whole car burned. nissan should still honor the recall. my 87 was done in '96. good luck
Old Apr 21, 2005 | 01:07 AM
mikeshammer's Avatar
Can anyone direct me to an area that may help me with a stumble problem? I have an 86 and have swapped out the maf ,the head temp sensor new plugs wires and cap. It starts, and runs fair, but if you try to open the throttle fast it dies. If you feather it above 1500 then it will rev with no problem. I have had several dealers look at it and no help. Its too nice to junk out at this point .( had that recall done) cost nissan about 1000$ I was told. They have to stand behind it for life I was also told. I am new to this so be kind with me, I'm an old man. HAHA
Old Apr 21, 2005 | 12:14 PM
1madmax's Avatar
did you check your fuel pump and/or plug wires?
Old Apr 21, 2005 | 06:03 PM
I am in the proccess of checking the fuel pressure . it runs too smooth for anything to be electrical. it has something to do with fuel or the control of it. I cannot find out what the fuel pressure should be?
Old Apr 25, 2005 | 01:12 PM
Well Mike, I'm looking at apparently the same problem as you with my 86, by any chance would yours happen to be the luxury addition with the digi-dash also?
Anyway, I'm calling Nissan today to check my vin ::crosses fingers::
Old Apr 25, 2005 | 01:31 PM
Just called... they say there are no "open recalls" for my vehicle... Personally I think they just went on the nissan website and looked, because I've done that already, is this worth calling Nissan and getting moody?
Old Apr 25, 2005 | 03:47 PM
Niku-Sama's Avatar
your may not have been affected too, you never know...i'm gonna call them in a few minutes about mine
Old Apr 27, 2005 | 12:48 PM
Ogenerous1's Avatar
im a long time reader, just have never posted.
My 87, was made in 86' and i recently brought it up to 7500ft from 1000ft, and its now having all the aformentioned issues. I called nissan and they cannot pull up my vin at all...... they say its not in their system. i am not the original owner, does that make a difference?
-rich
Old Apr 27, 2005 | 12:53 PM
cardana24's Avatar
Blown
-rich
you being the original owner has no bearing on whether or not they do the recall, if it has not been done then they have to do it if your car qualifies for the recall.
Old Apr 27, 2005 | 03:25 PM
no mine does not have the digi dash. I cannot find where to install a fuel pressure gauge in the line .Any help with that?
Old Apr 29, 2005 | 08:05 PM
SurraTT's Avatar
HR Swap Pioneer
What other recalls are there?, and i have a ?, i cant make a new thred yet cuz the 15 post crap,
i got a 87 , the sensor light is on, and the oxyen sensor has had its wires cut completly off, but the plug comming from the harness is still on, i took the oxygen sensor out and it was really small around, all the parts stores did not have one that would even fit , they had one that did have the right plug tho, anyone else have this problem? its really bugging me. why is it so small?
please help me , i need to get the car inspected, (im driving it) ive been looking around and havent seen anything on oxygen sensor
Old Apr 29, 2005 | 08:51 PM
SurraTT's Avatar
HR Swap Pioneer
here is what i need
http://img.eautopartscatalog.com/live/C501064975NTK.JPG
here is what all parts stores gave me
http://img.eautopartscatalog.com/live/C501033527BOS.JPG
Old Apr 30, 2005 | 01:37 PM
Becia's Avatar
Surra,
I was told once the car hits a certain milage, the sensor light just comes on anyways (like it' old, or something). Mine's on as well.
Old Apr 30, 2005 | 07:52 PM
SurraTT's Avatar
HR Swap Pioneer
i know that, but my sensor has been cut off and isent even hooked up,
ps: to turn off sensor light go to fuse box and under it will be the wire it says to unplug after 99,000 miles or something
but my problem is the sensor is not even hooked up so i know its not working
Old May 1, 2005 | 10:00 PM
Niku-Sama's Avatar
that seccond pic of surra's, coult it be a CHTS?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
