Turn Lights
check the light bulb connection thats what was wrong with mine i got those new bulbs with the 2 connectors on them and the light fixture has one connection so thats prolly whats wrong. or your bulbs blew out..........
I had a similar problem. There is a relay on the driver side of the engine bay, close to the battery that goes to these lights. I got another one from the junkyard and mine have worked fine since. I will try to search and find the thread because someone took a pic and showed me right where the relay was.
*edit* I got the hook up! check it out
http://forums.maxima.org/showthread....ghlight=lights
You might also want to check the bulb and the socket.
Sometimes corrosion and rust will interrupt the circuit.
A little steel wool (with the power off of course) can
clear the contacts. Be sure to blow the excess steel
wool away when you are finished.
Originally Posted by UberZogster
Ok well i hit a huge pothole the other night which bounced the car and just made everything go everywhere and when i got to my road the side light came on with the blinker..... something is loose somewhere.....
tsi6001
10-03-2022 10:23 PM
kirkhilles
08-08-2015 10:53 AM
