Projector Parking Lights
Ok ima switch then I just thought that I could get both high and lows with some work on the H7 but I guess not. didnt use em at first cuz there was a lot of work to retrogit them but I guess ill change now. as for the gass door I used the electric one from a M30, I also got my hands on some carbon fiber and I put it on the gas door, not that cheap vinyl its the good stuff i had some left over so I put it to use, as for the oil change button sounds like a good idea but would require a whole lot of fabrication.
9006's arent as bright as i thought they would be but im still workingon it.
Projector headlight version 2.3... the bowls in the projector from the BMW were fading turning the cream plastic color so I took out the high beam dish from a Mitsubishi diamante which are maybe out of a light gauge steel with chrome these prove to work better than the paint that was fading that’s why the light in the beam pattern wasn’t bright enough using the high beam 9006 bulbs.
I got the carbon fiber from off of e-bay is was about the size of a sheet of paper 8"X11" bout 7 dollars to ship got the sheet for 7 dollars so a bout a grand total of 12 bucks. Now im hooked on it i gotta carbon giber everything that is that brushed aluminum color i.e. P/W window controls already did the A/C dash and other parts of the interior even the ***** on the dash. Carbon Fiber is the best.
sctludwig
Sep 1, 2022 01:32 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
