Fuel Pump
Old Dec 18, 2005 | 03:15 PM
ray_289's Avatar
Fuel Pump
i finally got around to taking out the fuel pump in my 87..my uncle was helpin me and he said the gas in there looks dirty and that i should drain it out and clean the tank before i instally my new pump..how would i got about doin this..the gas is couple months old...do u guys think i need to drain the old gas or can i just install the new pump?
thanks
Old Dec 18, 2005 | 11:13 PM
kiwikev's Avatar
you'd have to take the tank right out to clean it out properly. even then it's pretty near impossible to get every little bit out of it. as long as it hasn't got a huge amount of sediment in the bottom of it, i wouldn't worry too much about it. just put the new pump in and make sure you don't run the car too low on gas, otherwise you'll end up sucking all the sediment off the bottom and running it through the new pump. make sure you replace the fuel filter when you put the new pump on too
Old Dec 19, 2005 | 05:49 AM
max95q's Avatar
Or you could tackle it. How? Im not sure. You may end up having to get it out. If you are serious about making sure you dont need a new pump in the future because of sucked up sediment I would suggest cleaning it out. I would suggest looking up what would be the best way to accomplish this. Because I know if I dont have money at that moment for gas I usually can let it go past the E for awhile sometimes. Im sure some people have done this as well.
Old Dec 19, 2005 | 09:16 PM
Niku-Sama's Avatar
if it gets near E in my car it starts to act funky (like on the line) i have a "ghetto" suggestion....
why not take the filler neck off put a bucket underneath it and jack the car up on the passenger side so it all runs out, and then go in there with a hose from above where you took the pump out and slosh a bit of water arround to get the sediment out....change the bucket before you slosh water arround, the gas may still be bad but it'd be good for a lawn mower or something, and then put the filler neck back on.
just a thought...just make sure the tanks dry before you put it all back together, a little water is ok but it doesent take much to throw it outa wack
Old Dec 20, 2005 | 05:01 AM
max95q's Avatar
I can go a good while past E on mine before it starts to stutter. Mine will only stutter once it gets to E when its in the summer and I have had the a/c running.
Old Dec 20, 2005 | 02:30 PM
ray_289's Avatar
do u guys think i can put the new pump in without draining the gas? the ppl i asked are givin mixed answeres so iam not sure wut to do..it sounds like a big job an i dont wanna mess anything else up so iam only gonna do it if i have too..wut u guys think??
Old Dec 21, 2005 | 12:49 PM
kiwikev's Avatar
i would just replace the pump. it's too much of a pain in the **** to remove the tank and clean it out.
Old Dec 21, 2005 | 05:16 PM
ray_289's Avatar
aright i geuss ill just change the pump out..is it mandatory that i change the fuel filter too
Old Dec 22, 2005 | 09:14 AM
kiwikev's Avatar
yeah, it is. you'd probably void the warranty on the new pump if you don't
Old Dec 22, 2005 | 10:45 AM
maximase86's Avatar
I love lamp.
Huh??? 10 chars.
Old Dec 22, 2005 | 11:53 AM
Maxwell Smart's Avatar
I assume the fuel pump is in the tank? If so, then just run a length of tubing through the hole at the top of the tank and siphon the fuel and the sediment out. Once you have the fuel/sediment mixture in another container, let it sit for a couple days for the sediment to settle to the bottom, then you can rack/siphon the fuel off the sediment and either put it back in your Max or keep it for the lawnmower or whatever.
Old Dec 26, 2005 | 09:40 AM
ray_289's Avatar
how do i siphon it out? i got a 5ft clear tube to use
Old Dec 26, 2005 | 07:04 PM
If you can see into the tank (or even if you can't) feed the tubing into the tank. Then with the other end of the tubing at a point as far below the bottom of the tank as possible, suck the gas through the tubing (with your mouth) until you see it coming your way and then quickly place your end of the tubing into a catch can/pan/tank/drum/bottle/jug. The more the elevation change between the beginning of the tube (gas tank end) to the other, the more suction you'll have and the greater the ability of the syphoning action to suck any sediment out. Good luck.
Don't tell me you've never syphoned all the gas out of a friend's car back in highschool. Simple pleasures. . .
Old Dec 27, 2005 | 12:01 PM
ray_289's Avatar
iam in highshool right now
Old Dec 28, 2005 | 01:27 PM
16 years old. . . that would make sense. Good luck with it.
Old Jul 10, 2009 | 02:52 PM
Bcozzi71's Avatar
How much is a fuel pump?? I need to move my sisters car and the fuel pump is bad. Everywhere I call its like 300 bucks
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
