Complications Of An 87 Nissan Maxima
Old Feb 17, 2006 | 07:05 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
1. i have this startup problem itl go...click,......rummm,...ruu..mm,..ru
but then i attach a charge pack to it it starts and runs all fine until i turn it off..
i think its an alternator??
2. im missing buttons: trunk, shock control.
3. one of my struts are dead in the front unless there is a way to fix it with the button
4. i have to adjust the trunk to open
5. i have no high beams in my projector setup (could be grounding problem)
6. i got an 87 300zx automatic ecu and it dosent work dont kno why? will get another one to see whatl happen. updates soon to come 300zx maf wont work as well, maybe because of the ecu.
7. got a "different" not new muffler from the yard its a ricer one i didnt bring the say to remove the magnaflow dual exaust one....
8. gotta install the stereo almost there just gotta plug it up
9. why does the 87 need the hose from the crankcase and the 85 dont?? i kno theyre the same engines but with small adjustments but what does the crankcase put out on the 87 that it dosent on the 85?
10. if i put 300zx turbo injectors from an 87 on to a maxima year 87 whatl happen" if itl produce a better engine sound with a hp bonus lemme kno
11. gotta relocate the batt to the trunk for the ram air setup with the hood scoop and rx7 air box with k&n filter
12. it took me 1 hour to figure the intake setup out
13. still gonna do the turdo upgrade but not gonna swap engines
14. if i was gonna swap the engine i would do the vg33e with the vh45dek pistonsand have a 4.3 liter turbo sleeper i thhink itl work if not ill make it
15. mmmmmmmmmnissan vg34et
16. if ne one has any suggestoins comments please lemme kno i need em..
17. if your reading this youve gone through too much trouble and you need to find sometim else to do than be on the org......j/k
Old Feb 17, 2006 | 10:11 PM
TylerW's Avatar
#1 sounds like your battery isn't holding a charge. You need a new one. If it was your alternator, you would be able to run the car off the battery for at least a little while, depending on how well you charged it up.
For #10, you need to know the size of your original injectors compared to the twin turbo Z injectors. The difference will be pretty large. I'm confident that you will need some form of fuel control for them, in the form of an SAFC or Emanage.
Old Feb 17, 2006 | 10:14 PM
TylerW's Avatar
BTW if you need some crimped 4 ga wire for your battery relocation let me know.
Old Feb 18, 2006 | 05:59 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
ok for the battery it is new i got it from walmart yesterday same situatuation ill get a new alty and see whaty happens...as for the 4 gague wire i for some from a bmw 3 series seems long enough but thanks for the offer
Old Feb 18, 2006 | 11:05 PM
Niku-Sama's Avatar
the hose on the front valve cover?
thats just a venthalation thing.
Old Feb 18, 2006 | 11:11 PM
kiwikev's Avatar
i'd check to see what the alternator is putting out before you go and replace it. just get a digital voltmeter and hook it onto the battery while the engine is running. turn the lights, heater etc on to put a load on it...it should read around 13.5 volts.
check your battery cable clamps too. make sure they're not corroded and they're on the battery posts nice and tight and making a good connection
Old Feb 19, 2006 | 10:21 AM
TylerW's Avatar
To be more precise, it should be the hose that runs from the crankcase ventilation valve. Then again I haven't looked at a Max valve cover in awhile.
Old Feb 19, 2006 | 08:24 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
thats what i thought as well becaise it was on the 85 but on the 87 it aint....
as for the battery its connected tight but i will replace the alty tomorrow and see what happens tomorrow...
Old Feb 26, 2006 | 07:36 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
the problem with the starting was the starter swapped in a different one and started up perfectly. i was wondweing who knows ne one who does soundclips or video hosting i gots some stuff to show yalls....
Old Mar 15, 2006 | 09:11 AM
jp50662's Avatar
is it normal for my maxima to not run when that battery gets a little below 12 volts? it will crank over but not run. just wondering if this is normal.
Old Mar 15, 2006 | 04:52 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
you prolly got a bad alty (alty=aternator)
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
