grease in intake/tb?!
Old Apr 11, 2006 | 09:53 PM
neo_densetsu's Avatar
Ok, I got bored today and decided to go do some work on my max, so I decided to take out the TB and check and clean it. When I took it off, I was surprised to find a nice thick layer (1/20" thick) of grease in the TB and Intake manifold! Is this usual, or is something wrong? If something is wrong, what would it be?
Old Apr 11, 2006 | 10:13 PM
DJ Technischer's Avatar
Its carbon , Not grease.
Old Apr 11, 2006 | 10:16 PM
Ok, so it's carbon. Is this bad??
Old Apr 11, 2006 | 10:31 PM
No , Its normal but if you want a insty bit of better throttle responce try to clean as mutch of it as you can out , Its very hard to clean . Just make sure there is nothing left inside the Manifold after your done , Or you will screw up your engine.
Old Apr 11, 2006 | 10:46 PM
I was thinking of taking off the Intake Manifold and using a parts washer to remove all of the carbon in there. I will most likely do that if i have to pull the engine to put in a new rack & pinion, as well as some other engine work.
Starrider
Sep 17, 2015 07:26 AM
Bonka
Sep 14, 2015 11:18 PM
SusieQQ
Sep 9, 2015 12:14 PM
RealityCheck
Aug 5, 2015 06:18 AM
Avalon Racing
Dec 3, 2000 09:18 AM
