Still Have Engine Whine
Old Jul 18, 2006 | 01:13 PM
Edge's Avatar
I've got a engine whine that I can't locate. I've been all over the engine with a s***hescope and still can find it, but sound like it is coming from under the t-belt cover. It happens in all trans positions, at any temp and increases with engine speed. I have removed all the accessory belts to see if was the water pump, ps, alternater, idler pulleys etc. Oil pressure looks to be ok at the spec'd rpms. I then replaced the timing belt and tensioner pulley. I found the dealer installed the timing belt too tight and I thought I found the problem. I checked the t-belt covers for signs of rubbing. Still no luck. Anyone have a oil pump go out or have a bad torque converter? Any other ideas?
TIA
Old Jul 18, 2006 | 07:01 PM
maximase86's Avatar
I love lamp.
The engine will have a certain amount of whine from the timing belt. The version in these cars aren't quiet at all. I ran my car with the cover off and it sounded like it was supercharged.
S
Old Jul 19, 2006 | 12:41 PM
Edge's Avatar
If you got similar whine it sounds like it could a characteristic of this engine. I hope so....the car runs great otherwise. But, I would have expected it to happen right away, rather than 1000 miles after the dealer t-belt job. I changed the brand of t-belt when I did the job to see if that made a difference... same. FWIW, there is also a factory TSB on T-belt whine which says to adjust the belt tension to the lower end of the range of 15 mm deflection between the cams.
Old Jul 20, 2006 | 10:39 PM
Yayomax's Avatar
still brewin'
Have you checked the power st. fluis. The pump has a annoying whine to it. My lines have a small leak and the whine gets progresively louder as the fluid gets lower. It never really goes away, even when full. Pour a little in to see
Old Jul 21, 2006 | 09:26 AM
VG2VQ99's Avatar
I agree all VG cars have an annoying whine with faulty Power stering units even my old Z had that whine, If it turns out not to be your power steering then Its the Alt.
Old Jul 21, 2006 | 11:00 PM
Niku-Sama's Avatar
none of my alternators whined before they went out...i am on my 3rd in 5 years (whats with these things?)
power steering whines some times but it was when i had a leak which has been fixed.
Old Jul 25, 2006 | 10:12 AM
Edge's Avatar
Yes the ps pump was checked, along with all the belt driven accessories by removing all the accessory belts. So the alt, ps pump, water pump, ac comp and all idlers were all disconnected from the engine. I checked the noise source again and it seems to be coming from somewhere near right cylinder head (closest to firewall) maybe near the cam shaft pulley and block. The only things I can think of off the top of my head are a broken head bolt (there is a factory TSB on this) and a leaking/broken oil seal. These are plain bearings at the cam, so no whine should come from there. I haven't ever heard of a leaking oil seal making noise, but maybe the internal spring in the seal broke and is rubbing the cam. Maybe I'll pull the rocker cover first.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
