This is what is finally going into my car
Now that finals are over I am finally going to put the projectors that I have been putting off for more than a year. These projectors have no cutoff shield, but the projector bowl seems to do a good job of not dispersing the light, which surprised me, you be the judge.
dark photo
here are two without using flash but show more of what light is being let out
picture with full flash being used
soft flash
Do I need to create a cutoff shield of my own, or is the light acceptable? All of the scattered light shown on the pictures looks dimmer in person.
dark photo
soft flash
ok, looks like I will have to fashion one out of sheet aluminum. One more question, How do I do the color mod for these projectors? Is it just placing washers on the bottom 2 screws????
take a picture of the projector and i may be able to help you it looks as if you have a set of highbeam projectors youll need to get low beams tho
but before we go into all of that take a picture of the projector
the big issue right now is fabricating the cutoff shields. I bought some small sheets of aluminum from the Depo and I am going to take another go tomorrow at fabricating these babies. So far the light isn't too dispersed by the stock glass, and adds stealth (in my neighborhood it isn't good if people know you have something expensive in your car, it won't stay on for long)
I finished with most everything and my headlights are on my car. The only thing I wasn't able to finish was the fabrication of a cutoff shield. Oh well, it is worlds better than my last setup, when it comes to light output and glare as well(relatively small glare. Only nighttime will definitely tell though
update: finished fabricating cutoff shields, gonna wait till nighttime to test it out, so far looks good though
tell me what ya think.(I know the drivers side projector is a little off to the side, will fix that later.)
how did you know I like ELO??? hehe. Thanks for the compliment on the car.
BTW, are you going to go to the big oxnard meet on january 27th??? here is the link if you are interested http://forums.maxima.org/showthread.php?t=502349
BTW this is how the headlights look when the lights are off, you can hardly tell there is a projector in there, which I like
The actual retrofit takes a while due to the small vertical space in our headlight. HID gives so much more output than regular halogen, that I feel it is worth the time I invested. If you're going to go and get HID, you should also buy some HID projectors and retrofit them in, HID kits in reflector housings are known to cause glare(even in OEM HID) and they can possibly cause accidents. That is why most auto manufacturers are using Projector headlamps in their more high end applications, and especially in SUVs(which are notorious for blinding oncoming traffic due to their height).
BTW: I just colormodded my projectors yesterday, and I am loving them even more now.
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
