Anyone have an 88+ ECU?
Old Jan 8, 2007 | 08:15 PM
neo_densetsu's Avatar
Im attempting to Tune the ECU in the 2nd gen max. I've seen it done on Z31's, so im assuming the ECU is the same.
I was wondering if anyone had an 88+ ECU that they could open up and take a pic of.
Im curious at the location of the EPROM chip, the BIN file the program is stored on.
Both the ECU's I have, look differnt than the ECU thats shown in the Z31 tutorial. I have 1 from my 85 Max, and 1 from an 85 Z31 N/A, both are differnt.
The Z is marked with 24, and the Max is marked with 75. What Numbers do your ECU's have marked on them?
If you would like, please list the Number on your ECU, and the model and year of your Maxima, or any other nissans you have.
If I suceede in this mod, I will be glad to burn chips for people to install in their ECU's for a small price (probably $30 or so).
My Main goal is to change the TP (theoritical pulsewave) of the injectors to match the larger Z31 Turbo Injectors. But I plan to modify the Fuel and Timing map to enhance the power output for the turbo's, remove the top speed limiter, and increase the rev limiter. There are many things that are possible with the stock ECU, making it almost as good, or even better than an standalone unit.
Old Jan 10, 2007 | 04:52 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
hey i can do this for you and have the pictures tomorrow i have a few ecus
i gots
87 maxima auto
85 maxima auto
85 300zx auto
87 300zx auto
86 300zx turbo auto
ill take pics of all just in cast not an 88 but its your best bet
Old Jan 12, 2007 | 07:47 PM
Awsome. Much Thanks. Once I get my ECU programed, I can burn you a chip for yours, to compensate for injectors and turbo.
The ECU is weird cause there are alot more chips on it than the new Z31 and 32 ECU's, they only have one ROM chip. Thats what I know how to program.
Old Jan 18, 2007 | 05:49 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
here are the pics to the ecu's still got 2 to go late nights at work and such one is in the car and the other is on the dresser
http://s134.photobucket.com/albums/q111/big_e-dog/
Old Jan 22, 2007 | 10:53 AM
Pacecar78_vette's Avatar
newbie here....how am I supposed to get enough posts to be able to ask a question about the maxima I just bought if I have not owned a maxima before and dont know enough about them to reply to posts and give advice.
Old Jan 23, 2007 | 01:41 PM
E-CARP's Avatar
'88 Ecu
My Main goal is to change the TP (theoritical pulsewave) of the injectors to mathttp://oem-surplus.com/nwp/maxima.htmch the larger Z31 Turbo Injectors. But I plan to modify the Fuel and Timing map to enhance the power output for the turbo's, remove the top speed limiter, and increase the rev limiter. There are many things that are possible with the stock ECU, making it almost as good, or even better than an standalone unit.
Try oem-surplus.com/nwp/maxima.htm
I've seen some on this site!
good luck, Earl
Old Feb 3, 2007 | 05:06 PM
Hmm... Both of those ECU's have 24 Pin EPROMs, The newer ECU's, like 87.5 300ZXT+ have the 28 pin EPROMS, which is what is needed for tuning.
Thanks for taking the pics. My 85 Auto ECU is the same, it has that weird daughterboard.
Now im getting into advanced electronics stuff, Im trying to get a PCB making kit, to make daughter boards that will work in the older ECU's.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
