Anyone ever have to replace...
Old May 23, 2007 | 03:17 PM
MarkC's Avatar
their coil? And, how did you determine that the coil was the problem?
I'm thinking I need to change the coil and/or the distributor cap because when it starts running sluggish, I can reposition the coil wire at both ends and it seems to perform better. This all started after replacing my plugs and plug wires. It ran fine before that. Any thoughts...?
Thanks!
Old May 23, 2007 | 07:54 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
i hope the plugs and wires arent made by bosch
if so get some ngk's
ive had to replace the coil once it was faulty and would just heat up
Old May 31, 2007 | 07:58 PM
neo_densetsu's Avatar
This might give you some idea if its bad or not. It requires a timing light.
If you use the light, you can see if a spark skips, if it does it could be the coil, but im not 100% sure that's the only thing that could cause that problem.
Old Jun 23, 2007 | 01:44 PM
Fatty Matty's Avatar
Where your coil wire enters the distributor cap, check for corrosion. It will be a powdery white type of corrosion. In the past, I've tried "cleaning" it up with a small wire pipe cleaner with moderate success. That corrosion isn't helping you out at all, and I'm willing to bet that is your problem. Replace the cap and rotor, just don't go with the cheapest they sell.
In reality, replace your plugs, wires, cap and rotor all at once. I always write the date and mileage down on my new cap if it's not black, that way you'll know in the future how much time is on it. Or I write it under the hood with a white paint marker.
Borrow a timing light from somebody and have them show you how to use it if you don't already. I believe the cap is the problem, but you'll also find out if you are timed right.
Old Jul 6, 2007 | 11:38 AM
MarkC's Avatar
Thanks, F M. I'll replace the cap, rotor, plugs, and wires this weekend and let you know how it turns out.
MidN1te
May 28, 2018 01:59 PM
moonlitesounds
23
Jan 9, 2010 09:30 AM
Eddiesalsa
22
Jul 30, 2007 09:51 AM
maximaSE327
Aug 17, 2006 01:33 PM
ke.max
Jul 14, 2006 07:24 AM
