anybody ever had to change...
Old Aug 20, 2001 | 06:10 PM
maxima561's Avatar
the CHTS, cylinder head temperature sensor? I think mine just went out today. The car will not stay running but when it does run, it runs fine. I just did the timing belt 2 days ago and i think i might of hit it or something. I scanned the computer and it had code 13 which is the chts. The scanner said to check the ohms and i did but there was nothing at all, so i guess the sensor is bad. The scanner also said that it will cause bad running and black smoke out the back, both of which i now have. Is this a common problem and how much is it for the sensor? Should i get it from the dealership or will an aftermarket one be ok to use?
Old Aug 23, 2001 | 09:11 PM
konan's Avatar
Replace it with a dealer part.
Aftermarket sensors are not very accurate and give false readings.
You said you replaced the timing belt. I would double check and make sure that you have a good connection at the sensor. You may have a bad connector of broken wire. Another problem may be that you did not bleed the air out of your cooling system enough.
Old Aug 24, 2001 | 02:28 PM
maxima561's Avatar
I got the sensor from the dealer and installed it yesterday. Car runs perfectly now. Cost for parts, about $40 including a new wiring subharness.
tnewbs
Aug 28, 2015 10:15 AM
theblue
Jul 15, 2003 04:32 AM
Scruit
20
Jan 10, 2002 08:21 AM
multiplexor
Aug 29, 2001 11:30 AM
