Ideal ignition timing.
Old Jul 13, 2008 | 09:40 PM
Fatty Matty's Avatar
I checked my timing today. I was about 3 degrees off, about 23btdc instead of 20. So I set it at 20, since that's what they call for with the automatic. It's 15 for the manual.
Not that I'm into messing with it anymore than I have to, but does anybody run different than what they call for? Why? More out of curiousity than anything else. I'm happy with the mileage I'm getting and mostly happy with the way it runs.
Old Jul 13, 2008 | 10:12 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
12 deg. high compression vg30ett 50psi on 270cc injectors, any higher and detonation occurs.
Old Jul 14, 2008 | 08:03 AM
maximase86's Avatar
I love lamp.
Ummm 50psi on 270cc injectors? Are you just being stupid or was that a typo?
S
Old Jul 17, 2008 | 10:54 AM
question.
why do they call for different timing for the auto vs the manual? 15 for the manual, 20 for the auto. does it run better for one or the other?
Old Jul 17, 2008 | 01:43 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
naah i was playin its more like 40 sometin
Old Jul 17, 2008 | 03:08 PM
vernk's Avatar
high compression vg30ett? did you do internal work also?
Old Jul 17, 2008 | 04:04 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
naaah im sure it can take it.
Old Jul 17, 2008 | 05:26 PM
vernk's Avatar
yea the bottom end of a VG will take 400hp, you said "high compression" and i haven't seen any place you have said that you put new pistons in bring it up from 8.5:1
Matty as far as the timing goes remember that a "factory tune" is set to be safe in all conditions, every thing from running 87 octane gas in 100+ deg. weather to running well in sub zero weather. As far as the differences between a auto and manual i think that a lot of it has to do with the amount of drag that the engine has when idling and fuel maps. I'm sure that there is way more to it then that but thats the best I can come up with at the moment.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
rnb754
Sep 14, 2015 11:39 PM
