Anyone Replace the Intermediate (Center) Exhaust Pipe?
Old Nov 1, 2008 | 08:01 AM
Edge's Avatar
This is the pipe between the cat and the header pipe, which has the flex section. Anyone know if there are studs or thru-bolts that hold the flanges? The cat side connections looks like studs which are threaded into the cat side flange and would have to be drilled or torched out. The head pipe side looks like thru bolts. I usually use a cutoff wheel on the thru bolts, remove them and replace with them new bolts. This won't work as easily on studs. Can anyone confirm? Any input on experience with a part brand fit?
Old Nov 2, 2008 | 02:23 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
if your maxima is untoughed its 17mm bolts and nuts, if some one modified it then your in trouble.
Old Nov 2, 2008 | 08:49 AM
Edge's Avatar
No mods, the car all original except for a OE replacement cat back exhaust and muffler
Old Nov 2, 2008 | 09:06 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
should be just bolts then
Old Nov 2, 2008 | 10:05 PM
maximase86's Avatar
I love lamp.
Every section should be bolt on/bolt off for the stock exhaust.
S
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 12, 2016 04:11 PM
vingodine
45
May 21, 2016 12:46 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
