A couple of issues with my '88 Maxima
Old Jul 24, 2010 | 05:48 PM
madgun68's Avatar
I'm trying to make a push to figure out the last problems with my '88 Maxima.
I checked the codes on the computer and all I'm getting right now is 23. Throttle Position Switch. I checked it with a multimeter and it looks like no matter how I adjust it, the switch doesn't "close" until roughly half throttle. From what I've read, this should happen when the throttle just starts to open. Is this right?
The only adjustment I see for this is the grooves that the screws go in to, which isn't enough. Is there some other way of adjusting these?
And by any chance, can I grab one of these off of a different model car? The pull yard here doesn't have any Maxima older than '89 and the parts stores are special order.
The other issue I'm facing right now is a vibration at idle, when the transmission is in gear (neutral/park is fine.) It usually does this, but not always. Most common culprit seems to be a bad motor mount, but on initial inspection the front seems fine. (Are there two? Where is the rear mount?)
Old Jul 24, 2010 | 10:43 PM
arsonist63086's Avatar
the tps is adjusted by those screws on the side of it.. 2 of the contacts need to be closed at idle and open at any other position till it reaches full throttle when the other 2 contacts close.... the tps can be garbed at the junk yard from any nissan as long as the tps look the same...
the car has 4 motor mounts from what i recall, 2 in the engine 2 in the trans...the rear motor mount is located in back of the engine by the axel....
Old Jul 25, 2010 | 11:55 AM
zcarmaniac's Avatar
If you can't find the part,check with Toyota/Nissan Salvage at 602-437-1222 or ABC Nissan.Both are in Phoenix,Az and have helped me find hard to find parts.
Old Jul 25, 2010 | 10:17 PM
madgun68's Avatar
The TPS problem has been solved. Stupid me.. I was looking at the diagram in the Haynes manual for the 89 (if I remember correctly) which only has one switch instead of two. I only checked one set of pins before concluding the thing wasn't working right.. It is. Now that it's adjusted, I don't see the stalling I used to get when accelerating from a stop.
Now it's on to the vibration issue. Question though.. I can tell that the left front motor mount looks good. The other I see in the manual is a lot more funky looking. How do you tell if it's good/bad?
Old Jul 26, 2010 | 08:03 PM
CMax03's Avatar
ABC Nissan is a good source for new parts... but they don't carry my old D21 truck parts anymore....So I'm sure they don't carry 1st nor 2nd Gen Maxima parts.....
Old Jul 26, 2010 | 08:44 PM
zcarmaniac's Avatar
Talk to George if you call ABC.He's excellent at finding things.Toyota/Nissan Salvage specializes in the older stuff,so check them out.
Old Jul 27, 2010 | 12:14 AM
CMax03's Avatar
I like ABC....I just don't think their service and shipment of parts are as prompt as Courtesy Nissan......but George is the man!!!!!!
Old Jul 27, 2010 | 06:47 AM
zcarmaniac's Avatar
Yes,he is.I think the shipping is done by somebody else.They've usually been quick on my orders.Sometimes,shipping people don't realize how imperative it is to ship quickly.
Old Jul 27, 2010 | 10:19 PM
CMax03's Avatar
With me being in Houston.....Courtesy normally takes about 2-3 days with most orders.....ABC quick has been 5 days......But don't get me wrong ABC Nissan prices can't be beat........
Old Jul 28, 2010 | 06:14 AM
zcarmaniac's Avatar
I see your point.
Old Nov 9, 2011 | 10:10 PM
josejrrios's Avatar
88 MAXIMA STALLS
I HAVE A 88 MAXIMA AND IT HAS A PROBLEM IT TRUNS ON GREAT BUT WHEN I ACCELERATE IT TRUNS OFF LIKE THE INJECTER DOESNT OPEN I CHANGE THW FUEL PUMP,FILTER,INJECTER,FUEL REGULATOR, TPS, OXYGAN SENSER,MAF DOES ANY ONE KNOW WHATS THE PROBLEM WITH MY CAR
Lakersallday24
Nov 7, 2024 07:31 PM
halfpol
Oct 17, 2022 12:16 PM
halfpol
Aug 5, 2015 08:24 PM
yat70458
Aug 3, 2015 01:16 PM
