Question for those that did a 1st gen L28 efi swap
Old Mar 22, 2011 | 09:17 AM
High5maxi!'s Avatar
ok so im currently swapping a l28 from a 1983 280zx into my 82 maxima. it this point im getting the engine harness connected but there are a couple of places im not sure what to do.
the first spot is the part of the wiring harness that runs along the firewall to the passenger side of the engine bay. it has the efi relay on it i believe but the other 2 connections im not sure what to do with (one of which is cut as pictured)
second one is on the intake manifold
does anyone know what id have to do with these or which ones are necessary for it to run? i only plan to run the efi untill i find some good carbs...
Old Apr 2, 2011 | 10:29 AM
arsonist63086's Avatar
you technically didn't have to use the 280zx harness you could of just kept the Max harness ans just cut the ecu plug from the max ecu and just start pin matching for the new 280zx. that's what I did to my 77 810 ... as for the plugs make sure u have the tps, cold start injector, coolent temp sensor / cylinder head temp sensor, air regulator.. also the 280zx uses a different ingnition module then the maxima (z= 2pin. max= 4pin) ..
Old Apr 11, 2011 | 04:17 PM
High5maxi!'s Avatar
i wish i woulda knew that earlier, i sold my old engine with the harness and everything D: you think someone would sell me one already done?
Old Apr 11, 2011 | 08:50 PM
yevgenievich's Avatar
i have engine with complete harness
Old Apr 11, 2011 | 09:02 PM
High5maxi!'s Avatar
how much you asking for just the harness?
Old Apr 12, 2011 | 10:08 AM
High5maxi!'s Avatar
doing a bit of wiring diagram studying. this is what got,
the L/G on harness goes to Lg/R on maxima's fuel pump relay
L/R on harness goes to L/G on maxima's fuel pump relay
Y/B on harness goes to B/Y on maxima harness
B/W and Lg/W from battery go to G and Br on harness through fusible link
L/Y on harness goes to B/W that goes to coil
sound okay? i havnt started any harness cutting yet
Old Apr 12, 2011 | 11:12 AM
if you want the harness i guess $50 or so.
Old Apr 12, 2011 | 05:10 PM
High5maxi!'s Avatar
i went ahead and cut/wired the harness together. fuel pump runs now. but i only get a single click when i try to start. is this happening because the safety switch that only lets your car start in park isnt wired up? since im going from auto to manual i havnt looked into how im supposed to switch that over yet..
Old Apr 14, 2011 | 05:13 PM
High5maxi!'s Avatar
got the starter working. coil isn't getting spark
Old Apr 17, 2011 | 02:17 AM
the coil don't have much going on to get spark. also depends oh the ignition module u are using. u must use the 280z module since its only a 2pin module and the Max is a 4pin (2top / 2 side - side pins are for ecu advance or retard o forget)... if u are using the z module ..
its 12+ to the positive of the coil and ignition module and the negative/trigger of the module goes to the negative of the coil .. u should get spark. to start up u must hook up the ECUs crank trigger wire to the negative of the coil
... I'm telling u all this at the top of my head from my experience double check it with diagrams to reashor yourself ... also Google 240z distributor upgrade so u can see the new ignition module wire up.
hope it helps u out
PS. I believe the ecu trigger wire is yellow and by it's self
Old Apr 17, 2011 | 12:03 PM
High5maxi!'s Avatar
got her running. somehow the positive and neg got switched. drives in all gear except reverse, probably the fact that my tranny is dry.. cant remove filler plug its frozen =[
Old Apr 17, 2011 | 12:37 PM
try filling up trough the shifter hole?
Old Apr 17, 2011 | 01:47 PM
good to hear its running .. filler up threw the reverse switch on the trans .. ..
Old Apr 17, 2011 | 03:07 PM
High5maxi!'s Avatar
tried, fail. D= im just gonna take it to a shop around here to see if they can heat it up or get it loose for me. yeahh i drove it in town today to the oil change place but they couldnt get it loose. theres a little play in the driveshaft and i need to get the trans mount on fully, its only on three bolts right now. i cant wait till its solid so i can really test it out! hahah
Old Apr 17, 2011 | 03:09 PM
High5maxi!'s Avatar
is it easy to get the reverse switch off?
Old Apr 17, 2011 | 09:06 PM
way easier then the filler plug ...
Old Apr 18, 2011 | 02:23 PM
High5maxi!'s Avatar
got it! still doesnt reverse... runs through all gears 1-5 though
Old Apr 18, 2011 | 11:31 PM
did it ever go into reverse? ... does it go into reverse when the car is off? if I does turn the car on in reverse and release the clutch slowly and see if it moves if it don't move tranny no good.... my tranny started clicking in reverse after i changed the gear oil. :'(
Old Apr 19, 2011 | 11:12 AM
High5maxi!'s Avatar
yeah reverse was fine before i took it out the 280zx. and it does go in reverse when its off. ill try. also, my oil meter on the dash isnt working and i dont think the temp meter is either... what do those connect to in the engine bay?
Old Apr 19, 2011 | 05:33 PM
High5maxi!'s Avatar
when i start it in reverse it works and shifts out of it fine but then it wont go back it without grinding
Old Apr 20, 2011 | 12:10 AM
in that case make sure your slave cylinder and fork are deactivating the clutch properly .. had that issue when I did a 5 speed upgrade on my 77 . ends up being I had air in the clutch line. 1threw 5 where good but reverse no go since 1 - 5 have synchro's and reverse dose not ..
Old Apr 20, 2011 | 12:15 AM
oil connects to sending unit by the oil filter it screwed to the block ... temp is on the thermostat housing its a one plug contaction ...
Old Apr 20, 2011 | 08:58 AM
High5maxi!'s Avatar
thanks a million. i figured out i have to get the oil sensor for a maxima since the one on the 280zx was 2 connections instead of the one. any hunches on the reverse problem?
Old Apr 21, 2011 | 12:01 AM
just check the clutch system .. bleed the line, or u might have a bad cylinder or slave cylinder... I'm saying cuz the clutch is not dissingageing probably ...
Old Apr 21, 2011 | 09:22 AM
High5maxi!'s Avatar
ohh ok isee. thanks again
Matt93SE
May 24, 2019 02:58 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
Finkle
Sep 27, 2015 09:53 PM
criminalslang810
Aug 16, 2015 08:12 AM
Blackwind
Aug 5, 2015 06:35 PM
