best option for exhaust manifold gasket sealing?
Old May 27, 2011 | 11:20 PM
demonics12's Avatar
hey guys, im freshening up a vg30e for my s12 notch, do you guys have any ideas for an ultimate solution for manifold studs backing out and/or gasket leaking?
im ready to spend whatever to make this work right. thanks in advance
-andrew
Old May 28, 2011 | 11:02 PM
broknindarkagain's Avatar
Andrew,
Put LockTite on the threads and torque down the studs to the proper specs. Using any gasket should do you just fine. Let the LockTite sit overnight before driving the car though
Old May 29, 2011 | 09:43 PM
demonics12's Avatar
Originally Posted by broknindarkagain
Andrew,
is this even with the factory studs? i hear early vgs have weak studs, and ive gone through 3 vgs, each leaked at some point.
is there a stainless option out there perhaps? something more durable?
thanks!
Old May 30, 2011 | 02:04 AM
CMax03's Avatar
Andrew,
Torque the studs???? That's not not how you install studs at all!!!! Purchase some new ones (Studs) from Nissan that come with a dimple on the end and these are the new and improved design.....place a little anti-sieze to the stud and screw them in until they bottom out that's it! Placing loctite on the threeds in this aluminum head could possible pull the threads out when removed the studs....
Old May 30, 2011 | 11:16 AM
demonics12's Avatar
thats what i figured.
im going to call nissan tomorrow about the revised studs, i hear tsb replacement parts are significantly cheaper than other parts since nissan "pays" for them. otherwise im going to look into some stainless hardware.
Old May 31, 2011 | 08:04 AM
CMax03's Avatar
Or call ARP for some general purpose metric studs....
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
carid
Sep 9, 2015 05:06 AM
videomano
Sep 8, 2015 03:28 PM
