anyone out there!?!?!
Old Feb 24, 2012 | 10:38 PM
Emerson85maxima's Avatar
I need help finding coil overs for my 85 maxima , or lowering sprains
Old Feb 25, 2012 | 04:49 AM
CMax03's Avatar
Try some KYB's with Suspension Techniques Sport Springs thru JcWhitney, Summit Racing, Amazon or eBay.....These spring are well designed and balanced....You can also try KYB's with coilover hat and springs....Not sure what spring rate to use but you will have too experiment! The Suspension Techniques is PnP....
Old Feb 25, 2012 | 05:28 AM
CMax03's Avatar
Suspension Techniques:
http://www.summitracing.com/parts/ST...n/?prefilter=1
Amazon;
http://www.amazon.com/ST-Suspensions...0176413&sr=1-1
Old Feb 25, 2012 | 05:48 AM
Hectic's Avatar
As for the lowering sprains, just walk around on your ankles for a few hours.
Old Feb 25, 2012 | 08:08 AM
haha i ment springs
Old Feb 25, 2012 | 08:09 AM
would these fit ? http://www.horsepowerfreaks.com/part.../12237//Nissan
Old Feb 25, 2012 | 05:17 PM
CMax03's Avatar
You read the application chart and the only Maxima listed was a 2000-03.....RIGHT? Then of course not! Here is my 3rd Gen settig on Suspension Techniques Sport Springs.....1.6" drop....
Old Feb 26, 2012 | 09:03 AM
CMax03's Avatar
I wish the best for you! I have a buddy with a really clean 87 Maxima that I was trying to give advice to regarding lowering his car.....Well just for comparing the 2nd Gen and 3rd Gen chassis they are also most identical! I made my suggestions and he chose the Ghetto a$$ method by letting a exhaust shop cut his coil springs....Then he wanted me to help him resolve his cars harsh suspension behavior! ST spring are inexpensive and easy too do with basic hand tools....Good luck I wish I had a 2nd gen as well so I could show you how it would look!
Old Feb 27, 2012 | 10:07 AM
alright thanks for the advice, one quick question the chassis off a 85-89 200sx the same as a maxima?
Old Feb 28, 2012 | 02:46 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
i think the springs on the rear of a 3rd gen are different, as for the 200sx, dunno, you might want to go snooping around a junkyard, or tha innanet...
Old Feb 28, 2012 | 10:25 PM
TransAmBandit's Avatar
I used S13 Cusco Coilovers in the front of my 2nd gen. I had to file one hole on the strut tower to get it to fit in and cut the brake line tab off of the coilover. Almost a direct bolt in on the front. The rear, I was going to experiment with cutting the strut housings and fitting a KYB AGX with Ground Control sleeves and Springs.
But I sold the car before I got that technical with it. My only regret was not using blown coilovers to test the front out. Haha
Old Feb 29, 2012 | 10:11 AM
CMax03's Avatar
hell no!
Old Feb 29, 2012 | 05:39 PM
maximase86's Avatar
I love lamp.
3rd gen springs are different, overall diameter of the spring is smaller IIRC. I ran a 3rd gen setup on my 2nd gen...the stuff to make it work is rather...much.
S
Old Apr 4, 2012 | 05:32 PM
OK guys I want to go lower then a 1.5 drop which is why I am asking if there are any coilovers that will fit be it from maximas or any other car? So if you can help thank you if not please do not respond with pointless answers.
Old Apr 9, 2012 | 11:11 PM
See post number 11.
