87 engine swap, help
Just bought my little brothers' 87 maxima. I recently threw a rod and froze up the engine. I decided to buy another used running engine from the local junkyard. I thought that I could just yank the dead engine out and put the other one in, but found out that it is not that simple.
Is removing the tranny with the motor the easiest swap, or could I yank just the engine? I removed and labeled every hose and electical connection to the engine. If I yank the tranny with the engine, do I really have to take the majority of the front end apart as well, i.e. brakes, shocks, transaxle, yada yada yada....?
Suggestions more than welcome,
Nick
Nick
Re: 87 engine swap, help
If all you need to replace is the engine, remove it only, leave the transmission on the car. It's alot more work if you take it all out, tie rods, ball joints, drive axles, all have to be disconnected. Check the CV boots for leaking grease to see if they need replacement. If so then you may have no choice but to remove them.
When you get the engine out, check the engine mounts, power steering hoses, presure/return for leaks, easier now to replace then later. My return hoses leaked oil onto the steering rack's rubber mount bushings, now won't hold the rack in place.
If you have a 5sp, will the clutch need to be replaced soon, if so, do it now.
Everything takes time, just do it right once and not have to do it over.
Al
Al
Re: Re: 87 engine swap, help
How exactly do I go about removing just the engine? With all of the hoses and electrical stuff tied off and the alternator and air conditioning compressor tied up, the road home to freedom looks like one big headache. Do I just unbolt the tranny from here? And if so, I can see getting to the two bolts towards the front of the car and the two bolts above the transmission, but what about the two bolts toward the firewall? If I unbolt all of those will I be able to get the engine out then, or will I have to...?
Nick
Nick
Re: Re: Re: 87 engine swap, help
Nick
Nick
derekinthez
11-13-2022 04:00 PM
fastcarny
10-06-2015 10:42 AM
