Timing Belt - How To -
Old Sep 1, 2012 | 12:53 AM
thetorp's Avatar
I thought it might be a good idea to write this up so it can be a sticky. It is right from the alldata shop manual.
Old Sep 1, 2012 | 09:04 AM
CMax03's Avatar
Perfect for a sticky good job!
Old Sep 1, 2012 | 02:11 PM
maximo018's Avatar
Man if only every other common thing wrong with 2nd & 3rd gens could be explained this easily.
Old Mar 9, 2013 | 11:34 PM
Edge's Avatar
Great idea for a sticky!!! Unfortunately Alldata did not show the t-belt deflection of 13-15 mm between the cams with the 22 lb force in the Final t-belt Tension Check section. They only show the force. Nissan also left this info out on there first t-belt TSB 19880418 , but included it in the later t-belt TSB 19921002.
Make sure you always check the deflection between the cams with the applied force as above. Never only rely on the wrap-up spring to tension the belt, that only gets you in the ball park to check for the final deflection-force. Also, do not use tensioner pulley clock position for the the final t-belt tension as shown in some other t-belt guides. Again use the deflection-force method.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
