so if i was going to make my 1st gen
Re: so if i was going to make my 1st gen
Originally posted by PeaBodyJones
as fast as possible, what would I have to do to it? I wanna run 13's or low 14's here people, tell me what I have to do. I want fatty bo-batty lists ya heard me! hookitup yo!
Re: Re: Re: so if i was going to make my 1st gen
Originally posted by bb525
wow thats pretty fast, can u still drive it on the street?
RB26DETT or Supra TT engine outa do it.
All of these engines all share the inline 6 cylinder configuration and I've seen a SupraTT engine swap into a 240z so why not the 810 maxima?
Originally posted by Shambo
I doubt either of those would fit
Re: Re: Re: Re: so if i was going to make my 1st gen
how did you get by the smog test, someone told me that its illegal to swap a older engine into a newer car. is that true?
hey how bout swapping the I6 turbo skyline engine from japan.
best of luck
Originally posted by black019
how come you 1st gen people with the sooped up engines dont post more? these engine swaps have me intrigued...
Easy Swap
The obvious swap for ease of drivability is the 280ZX Turbo. I can't believe nobody mentioned it. You can pull 300 rear wheel horsepower from the nissan L28 Turbo without changing valves, pistons, or head gasket. You'll need aftermarket turbo equipment, but its all easy bolt-on. Use the 280ZXT Borg Warner T5 5-speed behind it, or you'll blow up a n/a 280ZX transmission. It sets right down on your engine mounts and everything!
You'll need all the wiring and extra sensors on the engine of course, but its a whole lot more reliable than a Chevy! That engine might even pass emissions too! I mean, a 1981-83 280ZX Turbo probably is made for the same emissions regulations as an 81-84 Maxima
Also, only the 82-83 Turbo had the 5-speed option. All 81 turbo's came with an auto from the factory.
And don't even start using turbo parts on the L24 engine. The compression is too high on that engine for a turbo, the valves in the maxima's head are smaller, and the exhaust ports are smaller. Just use the whole 280ZX Turbo block and head
Listen to bleach he knows what he is talking about! You'd be amazed how far a 280ZXT's l28et will take you. You get get the thing for next to nothing. The only mods required is the oil pan(gotta make provisions for the turbo oil line on the maxima pan), the oil pickup(like mentioned earlier), and you gotta do the wiring for the 280ZXT ECU and harnes. Pretty much everything else is a direct bolt in! Add an intercooler and turn up the boost and you'll easly be faster than 90% of the cars here.
BTW I swapped a 280ZXT motor into my '77 using '77 EFI and igntion last month. Dont know how good it works yet cause I got some problems with my cooolant leaking. But I'm getting my radiator back friday and she'll be ready to roll!!
95Maxi
35
Sep 2, 2015 10:37 AM
criminalslang810
Aug 16, 2015 08:12 AM
