My steering suddenly hard to steer
Old May 5, 2020 | 09:38 PM
FanaticMadMax's Avatar
Need help here can’t figure out what gone wrong since I put new KYB struts and replace all the tie rod, ball joint and rebuild the ps pump since it was making noise and it stopped after I Rebuild the seals and now I have no steering when is on the ground but if it was lifted up and it steers, any input what gone wrong since I do have pressure but I need an opinion could the rack quick working ?
Old May 7, 2020 | 12:02 PM
alllw86's Avatar
If you open up the PS system you need to bleed the system. With wheels off the ground turn the steering wheel slowly full left then full right a few times. Forgot if engine needs to be running but won't hurt. Be sure to refill reservoir as needed.
Hope that helps, Al
Old May 8, 2020 | 05:23 PM
It was bled as per FSM I read thought and I think I have a bad pressure hose since it is 33 yr old original hose since my pump is working fine but it not squirting much pressure so I think I do have a bad Pressure hose I’ll find out this weekend when my part come in
Old May 10, 2020 | 06:22 PM
CMax03's Avatar
It's possible that you installed the check valve the incorrect way inside the pump?
Old May 12, 2020 | 04:19 PM
they were mounted correctly so I'm just waiting for hose to come in taking a while since Nissan did not have them in stock so I have to order from another company. It been a pending since the stupid COVID-19 delaying the shipment
Old May 12, 2020 | 10:43 PM
CMax03's Avatar
Possible trash clogging the steering rack's ports?
Old Jun 5, 2020 | 06:58 PM
It was the rack and pinion, the seal were slowly leaking and the port were clogged. So I pulled it out and did a complete rebuild, considering the car has 174k miles on it with the original Rack.
Old Jun 8, 2020 | 08:21 AM
CMax03's Avatar
My advice to everyone is to install an inline magnetic filter (5/8") on your power steering suction hose it can reduce the chance of clogging the internal passages of your pump or rack & pinion.
Amazon Amazon
Old Jul 26, 2020 | 05:34 PM
now my pump isn't working after a rebuild, it's not making pressure. So I'm licked, gonna go buy a new pump.
Old Aug 7, 2020 | 05:53 AM
Finally put a new pump and viola it works!! It irked me why would my old pump wouldn’t work after I rebuild it myself with new seals and bearing shaft? I read a lot online people who rebuilt their pump had the same issue it did not have pressure. I’m glad I got it back on the road
Old Aug 9, 2020 | 07:01 PM
CMax03's Avatar
I've rebuilt many pumps and never seen one not work after rebuilding it...I know it's easy and cheap and I'll do that for one that has a leaking seal over one that is making metal....Great effort anyways FMM.
Old Feb 11, 2021 | 02:19 PM
Maximer02's Avatar
My steering stalls intermittently at cold start but is fine while driving. I notice power steering fluid is not moving in the reservoir. Is this a sign of a bad steering pump or bad high pressure hose?
Old Feb 14, 2021 | 08:39 PM
CMax03's Avatar
Could be your rack and pinion!
jbbons25
Feb 11, 2014 02:39 PM
Kryogen
May 4, 2013 05:38 AM
kdarcangelis870
Nov 8, 2012 07:58 PM
DuMKuH
Jul 16, 2006 08:58 AM
sxwk12
May 5, 2002 05:08 PM
