LED swap 87 maxima SE
Old Jul 15, 2025 | 08:59 PM
MaximaMan22's Avatar
I think I jumped the gun. I switched out most of the lighting in my 87 SE to led bulbs. I did know to change the turn signal flasher which fixed the rapid flashing, but now, different issues pop up like light staying on when the car is off. Dash lights on before the lights are even turned on. Any suggestions or do I just switch it all back. I keep reading about load resistors. But can't seem to figure out the specifics of what to do.
Old Jul 16, 2025 | 02:50 PM
chrome91's Avatar
Been a long time since I did it but my '91 Toyota Crown I swapped to all LED and I did physical resistors instead of the LED flasher. IIRC it was just tapping the resistor one side into the ground and one into one of the + wires and that was it
If you unplug the flasher does it fix the dash light issue or not? That should narrow down if the flasher could be the issue or not
k757
Mar 25, 2014 01:55 PM
xspanishxkidx
Apr 9, 2011 09:14 AM
Zamochy
Aug 28, 2008 04:04 AM
ComradeJew
35
Feb 25, 2007 05:40 PM
thomasd cook
Dec 22, 2003 07:58 AM
