IA FS: 7'" Widescreen Monitor modified for 92-94 radio trim
was going to put it in the ICE category but its modified to fit a third gen so I thought this might be the place for it..
I have a 7" Widescreen PowerAcoustik monitor and bracket that fits perfectly in the double din slot on the 92-94 trim piece for 3rd gen maximas
I had it installed in a couple different sunvisors, so the brackets seen better days (its covered in glue and foam, not a lot but its definately not a piece you want showing). I now have the bracket modified so all you will have to do is put it against the back of your radio trim and mount it somehow (superglue, plastic weld, whatever you're thinking). the screen has a white power light in the top left corner and says "PowerAcoustic" at the bottom middle. you'll have to wire up the power and video cable.
its a little dusty but i assure you its in great condition and it sits very tight/flush against the radio piece...asking $90 shipped...
That looks rly sick and nice and flush too..I'm not use to seeing that there so I cnt tell..you had to remove the "push' thingy and the heat control *****..you don't have any other pictures that show the whole dash..plz? Lol I'm jus curious on the total look I'm interested in purchasing
ive never had it installed like this, ive only had it installed in sunvisors
after a couple installs the plastic bracket has glue and foam on it and doesnt look pretty but when I put it behind the radio trim I had inside, it looked really good so I modified it to be center (you butt it up against the plastic on the back of the radio trim that surrounds the vents for the ACC sensor)
youd have to get rid of your "push" cupholder and find some place to put your cd/dvd player. however the screen isnt very deep so you might be able to install your cd player farther back in the radio bracket and use a remote to control it, otherwise your glovebox is also an option
AC HEAT controls are above the double din and are not affected
TallTom
57
Oct 14, 2025 05:16 PM
