How many miles before timing belt broke?
Old Jul 11, 2002 | 01:48 PM
PhillyMax91SE's Avatar
hey ladies & gents,
I'm curious to find out when your timing belt broke, and how many miles were on the car at the time. My car is approaching 100,000 and there's no problems (knock on wood), but it's on my mind.
Thanks.
Old Jul 11, 2002 | 02:43 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: How many miles before timing belt broke?
Originally posted by PhillyMax91SE
hey ladies & gents,
Thanks.
i think by the time it breaks...it's too late. fix it now so it's NOT on your mind.
pay a little now..or a lot more later. your choice.
Old Jul 11, 2002 | 02:51 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Re: How many miles before timing belt broke?
yeah...what he said
Old Jul 11, 2002 | 04:09 PM
keener's Avatar
I had 130,000 miles on my last belt, but 95% of the miles were hwy. i started to get nervous when I noticed fluid dripping off the power steering pump tensioner. The fluid was not red...hint hint, it was brown therefore the only possibilty could be the rear cam seal. Once oil gets onto the belt you are in dangerous territry because the teeth an the belt begin to errode. The belt never actually breaks, rather the teeth shread off and advance the timing so much that the pistons impact the valves... by this time it is too late and you need an engine rebuild. Moral of the story unless you pulled the timing belt covers recently and feel 100% that the teeth are not beginning to crack, then I would say change the damn belt. At least you will be able to sleep easier at night. This is an easy DIY project so I suggest you spend five hours on a weekend and change the belt..aslo the H2O pump, thermostat, rear cam seal, tensioner, and crank seal. The parts will run about $100.
Old Jul 11, 2002 | 08:31 PM
Pervis Anathema's Avatar
Yep, what they said
The Mercury Villager can survice a broken timing belt. It uses a modified VG engine. Ford required Nissan to modify the engine before they would use it. Our cars cannot survive a broken belt.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
delerium75
Aug 19, 2015 11:08 AM
Maxgig
Aug 18, 2015 09:17 PM
