Foglight ?
Old Jul 24, 2002 | 10:06 AM
Mike92GXE's Avatar
Foglight ?
Ok after searching I found that GXEs are "wired" for foglights already. So i got under the car and in the dash and i found the wires. So I'm thinkin so now all i need is a relay and a switch right? Well it seems that the wire going to my dash doesn't fit directly onto the stock switch. Am I missing a piece that goes in between the two? I've called 3 nissan dealerships asking about a foglight wiring kit but no one knows what all it comes with and i don't want to buy the kit if all i need is one part. I've been stumped for a minute on this one so any help would be appreciated. And I'm ready to go back to the stock GXE grill with no emblem. Someone let me know if they want more info.
Mike
Old Jul 24, 2002 | 11:17 AM
«§»Craig B«§»'s Avatar
yeah, all you should need are the switch and relay
the relay plugs right into the blank spot for fogs in the relay box (in front of your battery), just get a blue one from nissan - part number should be on the other blue ones in there if you dont have it already
the switch should plug right in, you just remove the blank panel and the switch will snap in its place. Its wiring harness should be folded back and just taped to some other wires. This harness should just plug directly into the switch. There is a little clip on the top but that shouldn't stop you from plugging it in.
you can look at my webpage in the how-to section for kill switch and see what my stock harness looks like
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
