Strong gas smell when hot
Old Jul 29, 2002 | 04:56 PM
davis4005's Avatar
Since summer has started my 91 SE has started to smell like vaporized gas or ethanol when it's been driven 40 or more miles and is really hot. It's so bad it fills the whole garage and house with this smell and you can smell it really bad when your driving also. I'm wondering if it's an accumulator or the vacuum canister. It's definitelty coming from the front, but I'm stumped as to what it could be. Thanks guys.
Old Jul 30, 2002 | 07:43 AM
davis4005's Avatar
bump
Old Jul 30, 2002 | 09:56 AM
Jeff92se's Avatar
I'm needing a caw
The VG powered maximas had alot of problems w/ the rubber hoses that connect to the fuel rail leaking. I guess each injector has a little short run of rubber fuel injector hose that leaks when old. I don't know if there is a recall on this or not(there might be as I remember people talking about it) Also check all your fuel hoses from the filter to the fuel rail also. If you didn't say the smell was coming from the front, I would also suggest checking the rubber hose to fuel tank connection.
When the car is warm(and leaking) open the hood and see if you can pinpoint the leak(s). Be carefull as these types of fuel leaks can cause an engine fire. Get it fixed asap.
Old Jul 30, 2002 | 10:55 AM
Matt93SE's Avatar
STFU n00b!
As Jeff said, the VG has a history of fuel line leaks. I've seen a huge number of them in junkyards because of engine fires. get it checked out ASAP.
Old Jul 30, 2002 | 04:14 PM
davis4005's Avatar
Thanks for the help, I popped the hood open today when it was making the smell, and it is definitely coming from underneath the battery where the canister is. I don't know what hoses plug into it or what, but I'm going to remove the battery this weekend hopefully and check it out.
Old Jul 30, 2002 | 04:15 PM
Jeff92se's Avatar
I'm needing a caw
Good luck. Hopefully it's an easy fix. I don't remcommend smoking!
Old Jul 30, 2002 | 04:16 PM
davis4005's Avatar
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
ef9
Oct 4, 2015 08:43 AM
homewrecker
Sep 24, 2015 07:01 PM
