Paint Job
Paint Job
My car"s paint is not in a bad condition. The only problem areas are the hood, which has some little whitish marks on it. There is rust on the bottom front and bottom rear side skirts due to the salt and snow. And a little dent on the passenger side door molding. How much should i be looking to spend to get the aforemention fix and a new paint job for the entire car. Thanks for your responses.
Re: Paint Job
Re: Re: Paint Job
Originally posted by Clayton94GXE
..... Expect to spend at least 2000 - 3000 for a quality job.
I just got an estimate for my car, and it has a rather noticable dent in the driver's side quarter panel, assorted dents along the driver's rear panel, and a pretty faded spoiler. Even with the pearl they're gonna add to the factory paint, I'm looking at $1100. And that's from a VERY reputable shop in my area (NOT the so-called "ghettofabulous" paint man or the $99 Earl Scheib jobs either)!!
Re: Re: Re: Paint Job
Originally posted by nubiannupe
Good Gravy, man!!!
Good Gravy, man!!!
That sounds a little low dude. Are you sure they are not just pricing the body work..it would take at least a grand in billable time just to make repairs and do proper prep work..and by proper I mean removing ALL trim, lights etc, sand, prime, sand, sand , sand til it's straight (wavy paint jobs suck), color and clear on body, sills, inside trunk etc. I'd be skeptical, but I have seen some good local tradesmen whip out great body and paintwork for prices like this. Be certain before you plunk down your hard earned cash.
Good Gravy, man!!!
Good Gravy, man!!!
Re: Re: Re: Re: Paint Job
$2,000-$3,000 is too much.
You can get a car painted with OEM quality for $1,200-$1,500. You just have to look around. Some of you guys are in locations where there aren't too many car shops, places like NY are overcrowded with these shops and prices are competitive..somewhat.
More than just good prep work, paint price will vary with the number of primer coats, sanding in between, and color coats, sanding in between, and clear coats, snading in between. The paint can look all good smooth and straight, but a few years down the road, thin coverage will certainly show up. My uncle has a ferrari 308GTS..not the ultmate, but it has an insane paintjob on it..15 coats of hand rubbed laquer. There is a small nick in it and you can actually then see the depth of coverage, like 1/4"!. It means alot. If they are going to spray two coats with top of the line prep work, it will look good and cost 1500-2000, but don't expect to win and medals for best paint. It all depends on what you are looking for. Most will be happy with factory quality. You can always wet sand it later (if they didn't skimp on the clearcoat) for a supersmooth finish. Just be sure to pay a pro for that!
Originally posted by nismo1989
I did it myself. Body work, prep, paint, clear coat was estimated at $4200 and cost me around $800.
i'm not sure where u live (i was 2 lazy 2 look) but u have to consider that into your price...i live in fl where everything is cheap, so u gotta figure that inot the mix...i'm hoping to paint my car in the spring and was quoted 800-1k for just a job to keep my regular cheap white (i'ma do the prep myself) good job....
REDinLV
08-15-2024 12:30 AM
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
