top mounting 6X9's
Old Aug 2, 2002 | 11:34 AM
kingrye's Avatar
top mounting 6X9's
im going to under take this mod will some one post some pics and add there 2 cents. What tools? level of difficulty?
Old Aug 3, 2002 | 01:08 AM
kingrye's Avatar
help any body
Old Aug 3, 2002 | 09:06 AM
DaBoxSE's Avatar
You can do anything with time money and patience. I think this will be kind of an interesting job, and it would definitely be somewhat original in a third gen. Although, some things you may want to consider are functionability and quality. It also depends on what the rest of the stereo setup is, what kind of sound you are looking for and what kind of speakers you will be using in there.
The opening is set for a 6 3/4" speaker. 6.5" kinda fit but dont really. The Bose speakers are bottom mount because they were meant to provide mid and low range sound. Clarity and high range are not really heard from the rear speakers, but mainly from the front speakers. The rear Bose mounting brackets "funnels" the sound from the 6x9 opening through the 6.75" opening. This space acts as an enclosure.
Going back to the top mount 6x9's, I don't think that you will gain very much in low response, but you will gain highs. Its is good to have this kind of imaging in the rear because it fills the cabin with full range sound rather than just having all vocals coming from the front of the car near the floor.
With this in mind, I think that all that is neccessary in the rear deck are a good set of 6.75" speakers. Sure you lose some bass response, but you could always add a sub which you could tweak to your likings. Im just worried about cutting into the rear deck and then having the trouble of measuring the opening to the new speakers. Also, if your 6x9s have long-throw woofers, you'll want to cut the hole larger on the rear deck cover so that the cone won't hit it. Maybe you could raise it a little.
Thats my $.02, so if you do the job, dont forget to post pics, I'd like to see how it comes out and hear your testimony on the sound. Good luck bro.
|C
Old Aug 3, 2002 | 09:28 AM
FrankBattle's Avatar
Re: top mounting 6X9's
I have 6x9s in the rear deck. All I did was use the Bose frames. Now if you don't have the Bose frames, it's easy to fabricate a holder/frame to hold the speakers. Granted the cutout in the deck is not made for a 6x9, but for, I think, a 6.75" speaker, but if you mount the 6x9 deep enough, say about 1.5", you won't miss anything in terms of sound.
Is there any special reason you want to do top mounting? I mean besides the circular hole vs the oval speaker. It will be original, but not worth the trouble IMHO.
Old Aug 3, 2002 | 09:43 AM
DaBoxSE's Avatar
Here's my Infinity Kappa 652.3i 6.75" rear deck speaker.
Old Aug 3, 2002 | 10:58 AM
kingrye's Avatar
the only reason i want to topmount is beacuase they are bottom mounted right now and it sound like some thing is hiting the brakets and i cant get my infinitys to be tight(screwed down) enough i tryed modding the brakets(bose brakets) so that there was more room inside of it. I think top mounting will let me crank down how tight they are be cause right now they are fighting agians gravity and the volume they are fireing in to is small.
Old Aug 3, 2002 | 11:03 AM
kingrye's Avatar
my main problem is the right speaker rattles or rubs. cant tell which
when i press up on it it stops. i am very worried about the woofer of the 6x9 hitting the bose braket.
Old Aug 3, 2002 | 01:57 PM
DaBoxSE's Avatar
take the rear deck panel out. There are nuts that hold the the bose brackets in the deck. You may have some loose as it sounds and it may be your only problem.
Old Aug 3, 2002 | 03:39 PM
Maximajism94se's Avatar
i converted my rear deck to top mount...it just takes a little time and patience...i bought some mdf and made a whole new template to put over the metal deck and recarpeted the whole thing...i had to do it the time consuming way cause i didnt have a jigsaw, but if u do it'll b soooo easy...i had to remove some of the metal in the deck 2, but that was no biggie...i filled in the gaps b/t the mdf and the deck w/ the good ol' wal-mart mattress eggshell stuff
Old Aug 3, 2002 | 05:38 PM
kingrye's Avatar
i just want to buy a die grinder that hooks up to my air compressor and cut new holes in the sheet metal and top mount them and use my old back covering and grills
Old Aug 3, 2002 | 08:00 PM
whoa whoa whoa...u r remounting the bose speakers? i wouldnt recommend that...i'd imagine bose made the speakers specifically for the setup they is in...u wont get any treble response out of those even by top mounting them...new speaker+amp=goodishness
Old Aug 4, 2002 | 12:45 AM
DaBoxSE's Avatar
|C
Old Aug 4, 2002 | 03:17 AM
kingrye's Avatar
i dont have bose i have infinty kappa 6x9's in the bose mounting brakets they are too heavy i think to be bottom mounted read above to hear my problem
Old Aug 4, 2002 | 11:52 AM
Brandon90gxe's Avatar
kits not that hard, just buy some metal shears and go to town, cut out the right size for the speaker and shoot some screws to hold em down, evil yak did it on his car, cut himself up though from the loose metal , that stuff is sharp!
Old Aug 5, 2002 | 01:49 AM
kingrye's Avatar
how much are medal sheers i want some thing i can used to cut metal for the e36 conversion also
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
