Starter
Old Aug 5, 2002 | 05:39 AM
xavip_1999's Avatar
Starter
Hey there i have a 94 Maxima and when i try to start it, it makes a clicking sound and i im guessing its the starter. Can someone give me a clue to where its located.
Old Aug 5, 2002 | 05:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
right by the flywheel area..front of the car.
Old Aug 5, 2002 | 06:29 AM
xavip_1999's Avatar
Now i have 1 more question. The car started up and i took it to advance auto and they checked the starter altenator and battery and said they were fine. I came home cutoff the car and it started up ok. has anyone had a problem that resembles this?
Old Aug 5, 2002 | 06:41 AM
DanNY's Avatar
Ad·min·is·tra·tor
possible heat soak on the starter? does it not start when hot..and start when cold?
Old Aug 5, 2002 | 06:45 AM
Michael's Avatar
Back in a 3rd Gen.
I think a common problem with the auto is the "N" "P" switch. This will not allow the car to be started if it isnt in n or p. They will get flaky or out of adjustment and not allow you to start your car even when they are in the right position. I am just throwing out possibalities though because I am not sure if it will make a click when you try to start it.
Old Aug 5, 2002 | 06:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
well then if that's the case when he turns the key it wouldn't click.
Old Aug 5, 2002 | 08:43 AM
xavip_1999's Avatar
Hey im not sure what to make of it. Im going to take it to the shop in the morning because its getting a little sluggish( when i turn the key it turns over but slowly and i turn it of and turn the key and it starts sluggishly) when it starts up. and it did this when i drove around my block and cut the car off and then start it back up after 5 minutes. It runs great or it has. Thanks for all the suggestions though.
Old Aug 5, 2002 | 05:49 PM
leanfactor's Avatar
starter
i have the same problem. a machanic told me that its the exaust from the manifold. and that everytime the car is cold it will do this. the mechanic said that it is some kind of leak and is very simple. but i still await him to fix it
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
