something in the trunk????
Old Aug 13, 2002 | 10:31 PM
Jon610's Avatar
just interested in finding out what the round cylinder looking thing made of rubber and has about 20 wires running out of it in my trunk does??? and is that the thing that makes the humming noise just about everytime i get out of my car??? do our maximas have some type of level adjuster or something?? thanks for the help guys jonathan
Old Aug 13, 2002 | 10:49 PM
KLoWnPR109's Avatar
sounds like your power antenna motor
Old Aug 13, 2002 | 11:01 PM
RosenKen's Avatar
Andretti exhaust?
Old Aug 14, 2002 | 01:33 AM
James12345's Avatar
Re: something in the trunk????
Hey nice to finally see ya on the forums...
Member me on AIM?
Old Aug 14, 2002 | 08:16 AM
Jon610's Avatar
Re: Re: something in the trunk????
Member me on AIM?
yeah i remember you on aim. hows life treating ya??? and as i told you my Andretti exhaust is a local made exhaust. But no one has yet to answer my question i guess that no one knows. it has nothing to do with the radio. i just found the thing the other day when i was messing with my system. i used one of the 4 bolts that hold it down as a ground.
Old Aug 14, 2002 | 11:39 AM
Agamemnon's Avatar
Well, where's the thing located within the trunk?
From the description seem to suggest it's the power antenna motor, they do hum when you get out of car (or rather shut your radio off.)
Hey, maybe it's a bomb! After all, check the description again (cylinder, wires coming out of it...) Do you see any clock-type device in it? Does it make ticking noise? You have any bitter enemies?
Old Aug 14, 2002 | 12:57 PM
shavedmax's Avatar
is it behind the back seat?i have an 89, mine didnt have any wires sticking out of it. its right above the fuel tank. i dunno what it is but i took it off and no changes, so scrap it. it may have something to do with leveling the fuel, or as an internal roll bar, who knows, all the bolts dropped down except for one. for some reason it just doesnt come out. and the thing weighs like 20 lbs.
Old Aug 14, 2002 | 01:07 PM
Terry28's Avatar
since you bring this up, there is something under my the front passanger seat and i chacked under the front driver seat but didn't found anything but under the front passenger side seat there is something like an amphlifier or something with all wire hooked up to it. Does anyone know what is that? Thanx...
Old Aug 14, 2002 | 02:35 PM
Jon610's Avatar
i hope to god it isnt a bomb because it has been in there for years now. must have one hell of a fuse. hehe but anyway it is located directly behind the back seat. like the other guy said. but mine has lots of wires coming out of it. and it is making somekind of humming noise when i get out of the car.
Old Aug 15, 2002 | 11:15 AM
mtcookson's Avatar
can you take pics?
Old Aug 16, 2002 | 05:51 PM
91max180's Avatar
Its your motor that makes the antenna go up when your radio is on, and go down when not in use. I wondered the same thing for a while until I finally noticed.
Old Aug 16, 2002 | 06:35 PM
mtcookson's Avatar
the antenna motor is located where the jack is isn't it? this sounsd like it is directly behind the back seat.
Old Aug 16, 2002 | 06:40 PM
chchmax's Avatar
antenna
yeah, the power antenna motor is in the side, above and in front of the jack compartment.
Is it mounted on the rear tray, between the speakers or where exactly?
Old Aug 16, 2002 | 07:19 PM
Jon610's Avatar
it is directly behind the back seat on the floor of the trunk. it is not the power ant. making the noise it is the stupid round chunk of rubber in my trunk. it is factory. so if one of you guys would just walk out to your cars and take a look at YOURS you do have one i would think. or maybe it is just a gxe thing i dont know. thanks jonathan
Old Aug 16, 2002 | 11:51 PM
Jesse93GXE's Avatar
Is it on the floor of the trunk or hanging off the deck?
Old Aug 17, 2002 | 12:50 AM
mtcookson's Avatar
he just said floor
Old Aug 17, 2002 | 02:49 AM
JDwyer2821's Avatar
---------------------------------------------------------------------------------------------Guys the little rubber thing is niose reduction and the wiring gos to the fuel pump which the fuel pump makes a humming which indicates its working. Do I need to take a picture of this because I have somewhat gutted rear
Old Aug 17, 2002 | 03:04 AM
JDwyer2821's Avatar
http://maxima.cardomain.com/member_p...=153263&page=9 There does that show you what your talking about
Old Aug 17, 2002 | 06:52 AM
«§»Craig B«§»'s Avatar
I dont think that's what he's talking about
on GXE's they have a round cylinder mounted horizontally at the base of the rear seat. If you open the trunk, you can see a small hump at the bottom of the trim that covers the back of the rear seat inside the trunk.
All the SEs I've seen dont have this.
The things people have said before are it's for sound deading and to balance weight in the car.
Old Aug 17, 2002 | 07:43 AM
lp's Avatar
lp
Another theory is that it dampens resonance through the rear sheetmetal. Mine had one but I don't remember any wires coming out of it.
Jon if your rear is humming after shutting the door you may be the first person ever thats worn out your 'thing in the trunk'. Congratulations.
Could it be loose?
Old Aug 17, 2002 | 08:02 AM
pearl93max's Avatar
i've been told it was a weight too....You should be able to take it out with no problems.
Old Aug 17, 2002 | 11:20 AM
mtcookson's Avatar
but if it's just weight why would it be in the gxe and not the se. If it is supposed to help out the weight ratio i would think their sports sedan would have one too. (unless it's because the auto weighs more)
Old Aug 17, 2002 | 12:13 PM
Jon610's Avatar
the floor!!!!
Old Aug 17, 2002 | 08:51 PM
mtcookson's Avatar
i took a look at mine today. there are no wires in the actual piece. But i'm ****ing baffled as what that could be. It is this huge metal cylinder that is mounted on two mounts on either side that have a type of rubber thing in the middle. the mounts are exactly like the engine and tranny mounts but smaller. you can move that metal cylinder around and stuff. it's really weird. i was trying to look in my haynes book today to see if there was anything on it but i couldn't find anything and didn't even really know where to look.
Old Aug 17, 2002 | 09:06 PM
pest2001's Avatar
I know what hes talking abour if my system wasnt in the way i would take a pic. all i know is that its in the way for my sub box to go back more
Old Aug 17, 2002 | 10:17 PM
mtcookson's Avatar
almost sounds like an ecu. my friends acura integra's ecu is under the passenger seat. although on a maxima it's in the front behind the radio area. there are some nissans that have ecu's mounted under the passenger seat earlier trucks and pathfinders. you may just take your seat out to see what it really is. it's not that hard, you just need a socket wrench (i think 14 mm can't remember though) and take out the four bolts.
Old Aug 17, 2002 | 11:09 PM
D & S's Avatar
I believe this is what he is talking about:
As for what I've gathered it is a vibration dampener, and it also aides with the flex of the frame. Mine didn't have any wires attached to it, so I don't have any idea what the wires could be for. I recently took mine out when I built my custom box. It would have been cool if I could have built my box around it, but I think that would be pushing my already less than perfect carpentry skills, so I just decided it had to go. Once it's out you'll notice that it flexes very easily, but weighs a TON. I haven't noticed any difference with it gone. But I also Peal & Sealed my entire trunk, so that may have made up for the "Thing" not being there. I would imagine that if you took out both the "Thing" and the spare tire would would get a noticable difference in 1/4 times? Because combined they have got to weigh over 40 lbs.
Old Aug 17, 2002 | 11:45 PM
Jon610's Avatar
d&s dude you hit it on the head. that is what i am talking about. thank you guys for all of your help. i was wondering what it was because i would like to take it out so i can puse my subs back some more. thanks again guys. jonathan
Old Aug 18, 2002 | 01:41 PM
DaBoxSE's Avatar
Thats the first time I've ever seen one of those. I thought I was nuts when I didnt see that in my car, but then I read the thread again, and someone said a GXE thing. Learn something new everyday!
Old Oct 28, 2003 | 08:29 PM
Golden Ice's Avatar
hrm, I have a 92 GXE that doesn't have the "thing in the trunk"..i feel deprived..
Old Oct 28, 2003 | 08:46 PM
Burn MF Burn's Avatar
I think you are talking about the something for the phone antenna in the trunk and under the front seat is the computer for the phone
Old Oct 28, 2003 | 09:44 PM
grody's Avatar
Well, I guess we can't flame the guy for not searching. I was about to let jon have it, but saw that it was over a year ago.
Old Oct 29, 2003 | 07:16 AM
Matt93SE's Avatar
STFU n00b!
WTF?! talk about digging this one out of the mud!
Old Oct 29, 2003 | 09:46 AM
jaguax's Avatar
And still no answer as to why it's not in the SE
Old Oct 29, 2003 | 10:57 AM
Jon610's Avatar
You was about to let me have it?!! i never got an answer.
Old Oct 29, 2003 | 11:04 AM
timebomb's Avatar
look at the dates on this thread
whoops, didnt see that a few other people also mentioned that.
Old Oct 29, 2003 | 11:15 AM
Jack.'s Avatar
I have it too. It's a giant round cylinder that is kinda suspended between to brackets bolted in the trunk it hangs out in the very back and it's very thick and fortified. I have a pic check it out:
Not the best pic, but you get the idea of how large it is. It's located right behind the amp. This is the prime reason i built two boxes instead of one... I was afraid to remove it
Old Oct 29, 2003 | 11:21 AM
Gjohnson's Avatar
You can remove it. It does nothing. I can't believe you guys haven't found this answer before. I don't even have a GXE and I've seen these posts countless times.
Old Oct 29, 2003 | 11:49 AM
Jack.'s Avatar
i have an SE.
Old Oct 29, 2003 | 01:00 PM
jaguax's Avatar
The GXE would 0wn the SE in a game of chicken and/or head on collision with all the extra weight of that cylinder. We're like freakin tanks!!! lol
