Squeal From Speakers Or Deck
Old Aug 15, 2002 | 11:37 AM
90AZMAX's Avatar
ok i read that changing the speakers got rid of the awful noise from the bose audio system. is that al lthat need to be done or is the deck junk too??
Old Aug 15, 2002 | 01:16 PM
Lordrandall's Avatar
It's probably your amps. You can get them fixed, or trash the whole thing.
More info
Old Aug 15, 2002 | 01:19 PM
sabotosh's Avatar
if your deck is the OEM Bose deck (not aftermarket, the tape slot will say "bose" on it) then it will only work with Bose speakers. You will either have to replace/repair your Bose speakers with new Bose speakers or replace your headunit and speakers with aftermarket ones.
If you have an aftermarket headunit connected to the Bose speakers using an adapter you'll have to replace the speakers and wire them up directly to the headunit without the bose adapter.
Craig's site (listed in the FAQ at the top of the forum) should be able to help you out with the work.
Hope this helps.
Old Aug 15, 2002 | 01:31 PM
f40gt222's Avatar
Re: Squeal From Speakers Or Deck
Is coming from you stock Bose amps. Is better off getting new speakers and buy another amp... a 50watt amp (cheap..) should do the job unless you like to wake up the whole block.
Old Aug 15, 2002 | 04:06 PM
Intel's Avatar
Re: Re: Squeal From Speakers Or Deck
basic cd player for about 100-140 if you are not a audiophile and either some cheap components or a nice set of 6 by 9 speakers for just the front. (who cares about passengers anyways) and the wiring harnesses should suffice. Might need a amp if you wan't loud clean sound becuase a 100x2 amp for my front speakers made a huge difference for the price.
But this is only if you want to get rid of the whole bose system like most people seem to do.
Old Aug 15, 2002 | 06:31 PM
Agamemnon's Avatar
If you can isolate which speaker is squealing, you can disconnect them to get rid of the squeak. That's what I do! My Bose only have 2 (good) speakers right now (one dead & one squealing & disconnected) but that's good enough for me! Probably still sound better than some cheap system.
Old Aug 22, 2002 | 04:42 PM
90AZMAX's Avatar
Thanks for all the help!!!
Hey thanks guys, i guess the capacitors are bad so i will find which ones and replace them
ah yee aah
Old Aug 23, 2002 | 11:57 AM
eric93SE's Avatar
Mine squeels, but only when tapes are being played. Is that whats happening on yours 90AZMAX ?
b/c it would not be bad speakers, it just the belt for the tape drive that is slipping badly. Im going to replace mine too, or maybe I'll get motivated and start installing my system, its been collecting dust.
Old Sep 16, 2002 | 09:57 PM
maxima2k2's Avatar
mine squeals sometimes only, like when im driving down the highway or something, but sometimes it gets so aweful, i just have to turn it off, even though when the volume is on the min its still annoying
magiconthetire
Oct 26, 2015 09:03 PM
Excalibur23
Oct 13, 2015 04:33 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
ChrisIve
Sep 21, 2015 12:01 AM
