lowering problem
Old Aug 20, 2002 | 03:34 PM
exco_05's Avatar
lowering problem
i lowered my car with sprint and tokicos..well here is the problem the driver side rear wont lower the same as the rest of the car..... what should i do????
Old Aug 20, 2002 | 03:38 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
how long has it been since you lowered it? if it is recent it may have to settle still. if it has been awhile and it's VERY different from the other 3 corners I would dissassemble and reassemble it. Something probably isn't seated correctly.
Old Aug 20, 2002 | 04:34 PM
exco_05's Avatar
it has been like 2 months and or a little more...
Old Aug 21, 2002 | 05:58 AM
GRNMAXDMON's Avatar
Im havin' the same problem as well except that the front right side of my car sits a bit higher then the rest of the car. Now I was thinkin' if I take off the 3 nuts from the strut tower and rotate the strut you think that would work I've had it like this for at least 1 1/2 years now. any help would be appreciated.
BTW, exco_05 if you find out first than me on whats the problem and how to fix it let me know too cuz seriously sometimes it looks like that there is an old fat lady sittin' in the back left side of my car
Old Aug 21, 2002 | 08:34 AM
Matt93SE's Avatar
STFU n00b!
1. the 3 bolts on the top of the strut only go in one way. they're spaced differently so they won't line up unless you've got it right.
2. make sure the bottom coil of the spring is seated correctly. looking at the bottom of the mount, you can easily see where the end of the spring should rest.
if you've still got height problems, I'd check to see where the weight is in the car. if you installed a system or something, make sure it's not off-balance. an extra 50lb on one side of the trunk can throw ride height to hell.
Old Aug 21, 2002 | 04:20 PM
exco_05's Avatar
thank you guys for the help i will try and let you know thankz again
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
slowlifer
Sep 8, 2015 05:53 AM
