cooling system air bleed valve ???
Old Aug 20, 2002 | 10:42 PM
rsemwal's Avatar
I have 1993 Nissan Maxima SOHC. I am planning to flush the coolant. I was wondering if my car has a cooling system air bleed valve. If yes, could some one please tellme how to locate it on my car. If no, how do I ensure that there is no air trapped inside after flushing?
Thanx.
Old Aug 20, 2002 | 11:34 PM
lp's Avatar
lp
Re: cooling system air bleed valve ???
Thanx.
Its the small bolt on the right hand rear side of the upper intake collector. From memory I think its 10mm.
Old Aug 22, 2002 | 12:55 PM
sublunary's Avatar
Re: Re: cooling system air bleed valve ???
it is a ten and to further help it is just below the throttle cable where a hose meets metal. make sure you don't loose the bolt when you take it off( the pressure will push it some) not that that has ever happened to me
Smackasmith
Feb 1, 2016 12:40 AM
tgreen
Oct 18, 2015 06:18 PM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
lux97Max
Sep 4, 2015 05:42 PM
