Problem With my ABS! Help
Old Aug 21, 2002 | 07:28 AM
Pepide's Avatar
Hi To All... First... I speak French... so i do some mistake when i write in english!
I just change my "cardan" since i change it the ABS seems to be a bit to "sensitive" Normaly the ABS is working when the tire is not "rotating". But Now When The car is doing about 1 to 5 km/h (1.3 mp/h) the system of the Abs "Think" taht the tire is not "rotationg" and The Abs try to Unlock The brake... The result is that i'm doing a few feet more when i'm braking for a Stop or a Red Light...
I konw the problem so i brake a little bit before the stop...
Did Any body can help me whit this mather... I wan to Sell my Maxima and buy a 2000... I'm doing a few repair before selling it... I dont want to sell a car that did not go well!
__________________________________________________ _
Pepide... Hopping That My English is not to Bad!
Old Aug 21, 2002 | 08:18 AM
nismo1989's Avatar
Re: Problem With my ABS! Help
Well, I think I understand your problem (although your english is a little rough ), and I have had this same problem. Your first thing to check would probably be the ABS sensor in the wheel. It could be dirty. If that's not the problem, you could always do what I did and disengage the system all together! (I hate ABS anyway). If all fuses and connections seem to be fine with the system you may want to have it looked at, but it definitly sounds like an ABS system problem. Good luck...
Old Aug 21, 2002 | 08:31 AM
Pepide's Avatar
Re: Re: Problem With my ABS! Help
Thanks... It's maybe durty in fact! I will check it tonight. I have tought to disengage the system.. but I change my "Cardan" to have the Abs Work again...
I'm sure my English will improve with the time...
Pepide... MAxima... What Else Do You Want?!
Old Aug 21, 2002 | 08:46 AM
Matt93SE's Avatar
STFU n00b!
Seems to be a common problem with the ABS cars after they get older.
here's some info from a few crazy Brits who know more about it than I do.
http://www.btinternet.com/~d.brooks1/abs.htm
Old Aug 21, 2002 | 09:22 AM
tmuscedere's Avatar
What do you mean by "cardan"
Old Aug 21, 2002 | 10:08 AM
nismo1989's Avatar
Yeah, I was kinda wondering the same thing... ??
Old Aug 21, 2002 | 12:51 PM
Pepide's Avatar
Re: Re: Re: Problem With my ABS! Help
I was thinking that it was the same name in english and french..??
Sorry My misstake!
it's: UNIVERSAL JOINT !
Pepide... Hmmm Need more practice!
Old Aug 23, 2002 | 05:45 AM
nismo1989's Avatar
Re: Re: Re: Re: Problem With my ABS! Help
Sorry My misstake!
Well, I would check the sensors like I said. It's an old car, they are probably pretty gunked up, or maybe malfunctioning...
Old Aug 23, 2002 | 06:48 AM
Bo Hill's Avatar
Re: Re: Re: Re: Re: Problem With my ABS! Help
Just remove the abs
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
wingnut2006
Sep 19, 2015 06:13 AM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
