89 auto trans problem
Old Aug 27, 2002 | 09:00 AM
jbenn's Avatar
My 89 Maxima developed a transmission problem over the weekend. First time of the day, the trans goes through the gears but does not want to shift to overdrive. When it finally does shift to overdive, nothing is there. It doesnt slip, it is just like it is in neutral. However, if I lock out overdirve and drive it for about a mile, overdive will then come in and the trans. acts normal, with good shifts and everything. What does it sound like is happening? All help is GREATLY appreciated.
Jeff
Old Aug 27, 2002 | 09:23 AM
jbenn's Avatar
fluid is full and looks great with a nice red tint even though it hasnt been changed in probably 75000 miles. FYI
Old Aug 28, 2002 | 10:39 AM
Uncle Pete's Avatar
The transmission has a feature whereby it will not select overdrive until the ATF has warmed up sufficiently. It is completely normal for it not to select overdrive when it is cold. What is not normal is for it to pick neutral instead! Best suggestion from me would be to try and change the gearbox control unit (mounted above the engine control unit behind the radio). I'm sure somebody here could sell you one cheap.
Mar 12, 2020 12:06 AM
bryants95max
Oct 2, 2015 12:52 PM
slowlifer
Sep 8, 2015 05:53 AM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
