the dreaded gas light
Being the poor man that I am, I often find myself with little gas in the car and sometimes the gas light comes on. How far can you drive with it on before you run out? My dad used to have an old Nissan station wagon that you could go about 30 miles with the light on.. it was funny messing with people who thought you had to get gas right away.
Re: the dreaded gas light
i thought it was like 15, but i'm sure i'm wrong...
Originally posted by mtcookson
don't try testing it. i did and ran out. i thought i still had a long way to go before empty. i'm know i did more than 20 miles on it.
You have about 1.5 gallons of gas left in your tank. So if you are on the highway when this happens you should have plenty of opportunity to find a gas station (unless you are in Kansas or Nebraska ). The problem with this, according to Click & Clack, the Car Talk guys, is you are putting a strain on your fuel pump and you may cause it the wear out prematurely. Rule of thumb is to never go below a half tank of gas (IMHO).
Re: Re: the dreaded gas light
Originally posted by metaverse3
A free piece of advise..I would avoid driving like that since it puts a strain on the fuel pump and it has to work harder, thus lowering the life expectancy of the part..
Re: Re: Re: the dreaded gas light
I will give you this one. You obviously know alot more about it than I do. I just remember listening to Click & Clack tell a caller that starting your car when you are very low on fuel has detrimental effects.
Re: Re: Re: Re: the dreaded gas light
i usually just put a spare can of petrol in the boot, and drive till it runs out, thats the best way to know, cause everyones fuel gauge could possibly activate the light at slightly different places.
i get about 45km from when the fuel light comes on, but thats at open road speeds.
Originally posted by male
I don't think so. How does this strain the pump? I realize that it no longer has the pressure of the fuel above the pick up adding to the static pressure at the pump inlet, but I doubt that would reduce the life of your pump. Pumps are selected for an application by looking at a pump curve, the characteristics of flow..volume (gpm usually) versus head loss (pressure imposed on the pump due to elevation, and friction losses in the pipes down stream. The aid provided by the static pressure as it varies with fuel levels is generally negelected as pump design is based on the duty point at the pump discharge (point on this curve where the pressure and flow fit the requirements of the system at maximum efficiency or close to it) When fuel levels change, the static pressure in the lines would theoretically change, but it doesn't in reality because there is the regulator on the other end "restricting" the line thereby maintaining necessary pressure in the line. If the static pressure drops in the line, the regualtor restricts the line, bumping the pressure. This does increse the load, but the pump is designed to operate there efficiently and safely. Don't sweat it. Now, if you go empty, the pump isn't made to move air and could burn out. But your car would quit before that happens. No more gas! I work with pumps so I know the design/selection procedure well.
Originally posted by medic
I'd heard somewhere that the pump uses the ful to keep itself cool, when you run too low, there is not enough fuel to keep the pump cool so it could fail early. Don't know enough about this to tell if it's BS, but I know I blew out a swimming pool pump becasue I left it running when the intake wasn't submerged, so the same principle could apply. Or would this go back to the item you mentioned about pumping in air?
Re: Re: Re: Re: Re: the dreaded gas light
Yeah, or like when they designed rear spoilers using spongy foam that retains moisture so that the mounting points rust and break. And to make matters worse, the spongy foam starts to disitegrate after 6 years
And to top it all off, the charge way too much for parts. Every time a mechanic gives me an off the cuff price for work, I know to add several hundred dollars to the repair for the parts. They always call back and say, "I am really sorry about this, but I had no idea that the part would cost this much, and I HAVE TO get it from the dealer."
Nissan windshield $1,300. Even the glass guys are suprised when they see this one. I am on my third windshield.
I still love my Maxima.
Maxima30
09-07-2015 06:13 PM
sdotcarter
09-02-2015 09:53 PM
