Need help in heater repearing
Old Sep 3, 2002 | 06:44 AM
HJcool's Avatar
My blower works ok, but doesn't get me hot air. The temerature doesn't changing even with AC. But when I turn temerature regulator, I feel some changes in airflow. What could be wrong with that?
Old Sep 3, 2002 | 07:01 AM
Brendan's Avatar
Maybe it just needs a charge??
Old Sep 3, 2002 | 12:35 PM
Taegost's Avatar
I think our HCU has a habit of dying out due to bad wiring... When I had my AC recharged, they had to fix the wiring for the button so it would tell teh ECU to kick the compressor on... I also can't shut my vents, and I'm thinking it may be the same problem, just need to fix the joints inside the heater control...
Unfortunately, I have the cable for the hot vent super-glued in place, so for me to do that is a bit of a *****... But I bet that's your problem.
Old Sep 3, 2002 | 04:57 PM
b2cute69's Avatar
Re: Need help in heater repearing
if you need parts im parting out a 94 gxe carries same parts as 89-94
Old Sep 3, 2002 | 05:02 PM
James12345's Avatar
Re: Re: Need help in heater repearing
What all are you selling? I may be interested in some stuff.
Old Sep 5, 2002 | 04:08 PM
b2cute69's Avatar
Re: Re: Re: Need help in heater repearing
what do you need or want? i have a brand new indiglo needle kit for your gauge cluster asking 65.0 plus shipping
Old Sep 5, 2002 | 10:41 PM
furious max's Avatar
heater problem
wasup peeps... i have a problem i'm up north and in the winter i don't get that much heat. even after i warm up my car. i get that good heat a while later. is it that the heater coil is clogged or i have to give it a radiator flush? i changed the thermostat. thanks.
Old Sep 6, 2002 | 10:10 AM
Brendan's Avatar
Re: heater problem
Ummm, post your own thread
Old Sep 8, 2002 | 03:32 AM
HJcool's Avatar
Re: heat value has vaccum lines control
Originally posted by 1989 4DSC
Hi
I had a problem with the heater not getting any hot water. Turned out the 2 vaccum lines to the water control valve on the fire wall got switched so that is was always closed. Check that and then there is the possiblity of air bubble in the water, for that there is a small drain cap / bleeder on top of the engine somewhere, search the threads.
Good luck.
Thanks a lot! But could you finger out where "the water control valve" and "drain cap / bleeder" are?
Old Sep 8, 2002 | 12:29 PM
HJcool's Avatar
Re: Re: Re: heat value has vaccum lines control
I have removed that bolt, but nothing happend. I satrted the engin and nothing happend agan May be my heater core really needs flushing?
howardis
Dec 11, 2019 06:10 PM
dr3am
25
Oct 22, 2015 08:53 PM
RWCreative
Sep 21, 2015 11:01 AM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 7, 2015 04:20 PM
