92 SE tire pressure?
Old Sep 8, 2002 | 01:09 PM
v1761's Avatar
Hi All,
I just bought a 92 maxima SE. manual, of course. very happy... Anyway, it doesn't have a sticker on the center console that is supposed to have a tire pressure. I searched the net, i got 26 and 29 psi recommendations. I think 26 is for manual and 29 is for automatic transmission (same both front and rear). Well, I wanted to verify it. Those who have the same car (or otherwise know) please let me know.
THanks a lot
vlad
Old Sep 8, 2002 | 01:13 PM
maxima420's Avatar
try checking the tires themselves. sometimes the psi is posted on them.
Old Sep 8, 2002 | 01:19 PM
PATRICK94SE's Avatar
That is the MAX-PSI the the tire will safely hold do not go by that. 32 PSI should do
Old Sep 8, 2002 | 01:22 PM
v1761's Avatar
I think that psi on the tires is the maximum the tire (not the car) is designed for, and therefore is usually much higher than the manufacturer recommended optimal. Is that right?
Old Sep 8, 2002 | 02:48 PM
Jesse93GXE's Avatar
CHeck the doorframe or B pillar for the sticker...
My 93 GXE is recommended at 29/29.
Old Sep 9, 2002 | 09:23 AM
max107's Avatar
My sticker (auto) says 29 for front & rear, but I usually keep them at 30 psi. My friend with a 93 SE (manual) keeps his about the same and has never had any problems doing that.
Old Sep 9, 2002 | 10:41 AM
medic's Avatar
29/29 for 93 SE auto. The tire place I go to though always puts them at 32/32. Doesn't make too much of a difference.
Old Sep 9, 2002 | 09:55 PM
nismo280's Avatar
maypop
wanna end up like the explorer's with firestones?... follow the reccomendation on the tire. I should become CEO of firestone, and re-name the company "Maypop"...
Tony
Old Sep 9, 2002 | 11:20 PM
Agamemnon's Avatar
Slightly overinflating or underinflating tires are OK, to adjust for your preference. As long as it's not extreme (like more than 10 psi difference!) Harder pressure give better response (to a point) because the sidewall flexes less. Lower pressure gives better ride.
The Explorer's tire problem, as I understand it, is because the factory tire pressure specification is already on the low side. Apparently the Firestone truck tires on Explorers made it ride like, well, a truck (which it is, really!). So to improve ride, Ford suggest a tire pressure that's probably close to the minimum neccessary for that tire. So when consumers never checked tire pressure and it fell below even the factory recommended pressure, it's now far below what the correct pressure for that tire should be. Hence the tires overheat and tread separate.
Old Sep 9, 2002 | 11:31 PM
nismo280's Avatar
yep
Old Sep 10, 2002 | 04:55 PM
92 Max's Avatar
Re: 92 SE tire pressure?
Originally posted by v1761
Hi All,
THanks a lot
vlad
I have a 92 SE. The sticker says 29 psi front and rear.
Old Sep 10, 2002 | 08:50 PM
v1761's Avatar
Re: Re: 92 SE tire pressure?
Thanks. However, is it automatic or manual? I think recommended tire pressure is different for AT and MT, as I said in the first post.
Agamemnon, you have 92 SE 5 spd. what does your sticker say?
thanks
vlad
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
