fog light bulb replacement
Old Sep 14, 2002 | 08:23 PM
maxima2k2's Avatar
hey guys what kind of light bulbs did you put on your fog lights? and what is the brightness number? is there anyway you can replace the fog bulbs, if so how do you change them?
Old Sep 14, 2002 | 10:17 PM
wyskibumm's Avatar
Re: fog light bulb replacement
Yeah, this is what I bought: some H3's. thats the replacement bulb. There are two bolts under the bumber, use a 10mm driver to get them out. Then unplug the whole fog light unit, and there are two screws connecting the glass and the black plastic. Use a #1 Phillips to get them off, then i took out the old bulbs. I had to cut the cord to get them out, and slide back the white heat guard. Then i plugged in the new bulb (after unpealing the tape) and got it all back together. Good luck.
Old Sep 14, 2002 | 10:18 PM
lophix's Avatar
sheesh! the boldness of the noobs.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
