idle at 1000 rpm??
Old Sep 25, 2002 | 06:43 PM
maxima2k2's Avatar
idle at 1000 rpm??
my car idles at exactly 1000 rpm?? is that the normal idle range?
Old Sep 25, 2002 | 07:10 PM
sabotosh's Avatar
Re: idle at 1000 rpm??
mine's usually in the 6-800 range, though it idles higher when cold in the morning. Does it idle at 1000rpm even when the car's been driving for a while?
I'm not sure what normal idle range is for our cars but 1000 seems a little high. My friend once had an old crown vic that idled at something like 2000rpm, you would take your foot off the brake and it would go flying, you could go 40 without touching the gas
Old Sep 25, 2002 | 07:31 PM
SecretAsianMan's Avatar
I lifted this from another website--
For 91-94 models it’s M/T: 650 (750 for Canada) and A/T: 800
--SAM
Old Sep 25, 2002 | 08:35 PM
maxima2k2's Avatar
Re: Re: idle at 1000 rpm??
when im driving and i take my foot off the throttle, it usually drops to 1000 rpm, doesnt go lower than that, ya usually in the morning that the idle range.
Old Sep 26, 2002 | 08:33 AM
medic's Avatar
did u do anything to your guages...you may just need to reallight the neadle to point to the right value. Lots of people screw up their speedometer if they don't make the proper location of the neadle when the switch to indiglo, this may be similar.
otherwise, if you adjusted your throttle cable, you may have it too tight so the throttle body is being left open.
do the idle go down when you're in gear and the engine is up to temp?
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
