Still the VTC grounding problem-Is there a mothed without cutting the wire?
Old Oct 10, 2002 | 07:10 PM
northrabbit's Avatar
I want to do the VTC grounding job. But I don't want to cut the coat
of the wire. Any other alternative options? Is there any connector
or quick splicer available to solve this problem? If so, please give
me a part number. Thanks a lot.
Old Oct 10, 2002 | 07:52 PM
«§»Craig B«§»'s Avatar
Re: Still the VTC grounding problem-Is there a mothed without cutting the wire?
the connectors I used and that are listed in the procedure for it dont require any stripping of the VTC signal wire
you can just unclip it if you dont want it on anymore
Old Oct 11, 2002 | 08:00 AM
Re: Re: Still the VTC grounding problem-Is there a mothed without cutting the wire?
Could you give me a picture or a link so that I can know what type of
connector are you using? Thanks.
BTW: Where to buy it, Radioshack or Wal-mart or any other place?
Old Oct 11, 2002 | 08:05 AM
410Fortune's Avatar
I did it without cutting the wire as well. Strip back the casing of the green/y wire with a razor blade to expose the wire without cutting it. I then soldered on the new lead and covered it with liquid electrical tape, then tape. If I ever want to go back I can simply snip off the soldered wire.
I prefer soldered connections over any type or crimp, I build conversion harness for engine swaps for OBD-I and OBD-II systems, I have had many crimped connections fail over time.
Old Oct 11, 2002 | 08:26 AM
Re: Re: Re: Still the VTC grounding problem-Is there a mothed without cutting the wire?
read the webpage (in the FAQ post here)
it has everything you're asking for and more
Old Oct 11, 2002 | 08:44 AM
Re: Re: Re: Re: Still the VTC grounding problem-Is there a mothed without cutting the wire?
Sorry, I visited all the webpages listed in FAQ, including your own
homepages, but I haven't found any connector you metioned. Could you
give me a picture of the connector you used? Thanks.
Old Oct 11, 2002 | 08:55 AM
Re: Re: Re: Re: Re: Still the VTC grounding problem-Is there a mothed without cutting the wire?
go to my homepage
click the how-to link
find VTC rewire on there
that first page it will take you to is a general introduction, at the top, there is a link to the other page which has instructions and it has pics and part numbers of the connectors that I used from Radio Shack. There are lots of other types of connectors that can be used including the "quick splice" or vampire taps that you can get at any Home Depot, Radio Shack or even Pep Boys
looks like this
btw, where in GA are you? I'm downtown at GT
Old Oct 11, 2002 | 09:18 AM
Re: Re: Re: Re: Re: Re: Still the VTC grounding problem-Is there a mothed without cutting the wire?
Thanks a lot.
I am in GT, too. We are colleague. :-)
go to my homepage
looks like this
Old Oct 11, 2002 | 09:28 AM
jwhite's Avatar
go to my homepage
looks like this
I got mine at Walmart. It costed me a whopping $1.66. It's made by 3M and the package includes the line tap connect plug and the male connector that plugs into it. The numbers in the lower right hand corner of the package are 03777NA. All you need now is a ring terminal and a piece of 14-18awg wire (about 6 inches long). Crimp the terminal on one end and the male connector on the other end of the wire. Expose the input (green/yellow) wire and clamp the line tap connect around that wire. Then, simply plug in the mating male. All you have left to do after that is unscrew one of the screws that is closest to the VTC solenoid, put the screw through the ring terminal and retighten. Then you're finished. The entire procedure took about a total of 5 minutes. And I am not in the least electrically oriented. As for the timing, the cam position sensor is on the driver's side head in the front of the motor. All you have to do is mark the sensor, unscrew/unbolt (12mm) the two bolts at the bottom and turn it clockwise about a 1/10 of an inch, then retighten. This whole procedure from start to finish took about 3 minutes, and I saw good results. Keep scrolling through the posts if this info isn't enough, because I knew absolutely nothing about Maxima's until about a week ago when I first learned of this site. It's been a huge help.
doctorpullit
Mar 29, 2016 11:08 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
