Will SE (white) gauges work perfectly in a GXE??
Old Oct 11, 2002 | 11:27 AM
AKAICEBERG's Avatar
I think I might have to replace my gauge cluster, so I might just get some white ones to dress things up. I know the SE gauges will fit, but are they calibrated the same as the GXE gauges?? I remember reading that the auto trannies in the SE and GXE where different and the gauges red differently. Is this true?
Old Oct 11, 2002 | 12:07 PM
mtcookson's Avatar
yes it will work fine. and no there is no calibrating needed. just make sure to get the 125 mph se gauge (89-91) and not the 92-94 or it won't work.
Old Oct 11, 2002 | 01:03 PM
Shadow1198's Avatar
Large Member
Actually, I have the 145mph gauges from a '93se and they work just fine.
Old Oct 11, 2002 | 02:57 PM
GRNMAXDMON's Avatar
I also have the 145mph gauges from a '93 SE and they work just fine for me also.
so if u get them either one will fit and will work. look at my cardomain site and u'll see them on page 4.
Good luck,
Rick
Old Oct 11, 2002 | 04:51 PM
mtcookson's Avatar
are they showing the correct speed and rpm??
Old Oct 11, 2002 | 05:06 PM
Shadow1198's Avatar
Large Member
I'm almost positive mine is accurate. The RPM is definitely accurate.
Old Oct 11, 2002 | 07:27 PM
GRNMAXDMON's Avatar
yeah im pretty sure mine is accurate but i'll try and find out for u man.
Old Oct 12, 2002 | 02:27 PM
Shadow1198's Avatar
Large Member
Actually, I know for a fact my speedo is accurate. There was one of those big speedometers on the side of the road (guess they were checking avg. speed of passing traffic). I got my car up to about 65mph, which is what my speedo read.
Old Oct 12, 2002 | 06:37 PM
mtcookson's Avatar
that's awesome. i'm going to go convert mine now, lol.
Old Oct 12, 2002 | 08:07 PM
TONY92MAX's Avatar
the SE cluster works for my GXE no problems - I did notice a slight variance in the temp needle, but haven't isolated the problem to a sensor or perhaps the needle itself.
Speedo and Tach are accurate. I calibrated using a Police Speedo/Radar machine sitting on the side of the road such as Shados1198 did.
Old Oct 13, 2002 | 09:41 AM
CMD89's Avatar
What did you do about the odometer. If you just unhook the old and hook up the new then the odometer is not correct. My speedometer has gone bad and would like to replace the cluster. I have access to an se (125mph) cluster but was not sure what to do about the odometer. Thanks the help.
Old Oct 13, 2002 | 09:59 AM
mtcookson's Avatar
i swapped the odo out of mine and it works fine
Old Oct 13, 2002 | 12:22 PM
Shadow1198's Avatar
Large Member
I never swapped the odometer. I wrote down what mileage each gauge cluster was at when I did the swap, for my own humor. I've already decided I am keeping my Maxima until it is completely dead. I'm not going to ever sell it to anyone, so I don't care as much about the mileage.
Old Oct 13, 2002 | 01:51 PM
TONY92MAX's Avatar
My maxima only has about 65,000 miles on it - I was lucky enough to find an SE cluster with about 62,000 miles on Ebay so I didn't really worry about the mileage difference.
Old Oct 13, 2002 | 10:10 PM
Max240's Avatar
Re: Will SE (white) gauges work perfectly in a GXE??
I actually have an se gauge cluster available if you would be interested. Let me know if you are. Good luck with the swap otherwise.
Old Oct 14, 2002 | 06:17 AM
pest2001's Avatar
hey max240 ill buy the gauges off of you e-mail me at krazepes@bellsouth.net mine just broke and i need them by this week and i have the money for them e-mail me i sent u an e-mail or a PM get backto me about it
thanx
william
Old Oct 14, 2002 | 08:47 AM
Max240's Avatar
pest2001--email sent. thanks
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
acw
Aug 13, 2015 12:50 AM
kenc15
Aug 5, 2015 08:29 AM
