for all with sus. tech. springs
Old Oct 18, 2002 | 05:21 AM
maxedout94's Avatar
which camber kit/bolt did you use, ive seen several out there but i dont know which one would be best, thanks
Old Oct 18, 2002 | 07:45 AM
nismo1989's Avatar
Re: for all with sus. tech. springs
None. You probably won't need it. If you do, the Ingalls replacement bolts will work fine... I have them on my car. If you need a set I happen to have one...
Old Oct 18, 2002 | 08:23 AM
AKAICEBERG's Avatar
I have ST springs and I had a rear alignment problem, but I think the reason for that was because I got an alignment done the very next day after I istalled the springs. So the springs never had time to settle in. I suggest that after you install them to let them settle for 1-2 weeks and then get an alignment. Another reason for bad rear alignment could have been because of very worn struts.
I had new KYB struts put on a long while ago and had another alignment done and I haven't seen any uneven wearing of the rear tires yet, but I still need time to assess for sure.
My mechanic was able to get all wheels into spec, so you shouldn't have a problem. If you have stock struts on your car, then do yourself a favor and buy new struts!! KYB's work great with ST springs because they aren't that tight of a spring.
Later
Old Oct 23, 2002 | 06:43 PM
whiteve
i didnt need one either when i got my alignment done
Old Oct 23, 2002 | 10:11 PM
Mizeree_X's Avatar
Getting back to his roots
Neither did I...I waited 2 or 3 weeks, went to NTB, and they fixed it up sans camber kit.
Old Oct 24, 2002 | 07:33 AM
MaDMaX024's Avatar
Later
i can definatly agree with that. i let my springs settle for almost 2 monthes after i installed them (i just didnt have time to get it aligned). but the KYB/ST setup is great except the front wheel gap is a little larger than the rear, kind of looks uneven.
also, i'm thinking about tokico or koni rears and keeping the KYB fronts, the rear seems a little soft.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
REDinLV
Sep 28, 2015 12:31 AM
followthadollar
Sep 27, 2015 01:06 PM
