stanza transmission
Oct 18, 2002 | 06:54 PM
Searched and found a couple threads, but no definite answer does the automatic transmission from an 89-94 stanza 2.4L 4 cyl DEFINITELY bolt up exactly with that of an 90 maxima. Any answers would be much appreciated, emailed a seller on e-bay who sells them saying that they do, still waiting for his reply. Need to find out soon, just waiting for the tranny to completely slip and leave me stuck somewhere.
Oct 18, 2002 | 07:14 PM
i've heard that the ka24 trannies do but i would recommend to search some more because i'm not positive
Oct 18, 2002 | 07:16 PM
Re: stanza transmission
The Stanza transmission will bolt up. The years you're looking for is the 1990-1992 Stanzas.
Oct 18, 2002 | 07:19 PM
Re: Re: stanza transmission
I also know the altima will use the same manual tranny as the stanza probably maxima also, as far as automatic's i wouldn't know right now if it'll work. That would be nice though, to be able to put in a low mileage altima tranny, since they're so common.
so would that mean all of the ka24 trannies should work? or is it specific (ka24e, ka24de)
Oct 18, 2002 | 07:35 PM
Quote:
I'm not gonna say yes..or no. It's a maybe. The KA24E trannys will work. Ka24DE manual tranny should work, auto i'm not sure about. It's worth checking into.
Oct 18, 2002 | 07:59 PM
which engine was in the 1988 stanza?
Oct 18, 2002 | 08:35 PM
Quote:
ca20e i believe
Oct 18, 2002 | 09:09 PM
the auto i'm sure won't work. i went and looked at a auto altima and the tranny was basically upside down coompared to ours. the big black pan thing on the top of our autos (i think the valve body but i'm sure since i don't care about autos ) it was on the bottom of the altima tranny. the bolt pattern appeared to be the same though.
Oct 18, 2002 | 10:20 PM
all of the 240sx's use the same tranny as the older non turbo 300zx's according to some tranny site i was looking at. so i think the ka24e and ka24de have the same bellhousing.
Oct 18, 2002 | 10:29 PM
sounds like theres still mixes messages, would anyone say %100 sure that the 89-91 KA24E Stanza transmission would bolt up with my car, I can't afford to pay the guy whos doing it to the job more than once.
Oct 18, 2002 | 10:31 PM
sudesh said the manual will work, he's not sure about the auto though. he also said you are looking for the 90-92 tranny.
Oct 19, 2002 | 10:01 AM
nah..the 90-92 Stanza Automatics are the same as the maxima automatics and will bolt up without a problem.
90-92 Stanza manuals may be the same, but you should check it out first. Probably would work easy.
I'm not sure about altima trannies.
Oct 19, 2002 | 10:45 AM
thanks
Would the Nissan dealership be able to tell me if i called them with reference to KA24E?
Oct 19, 2002 | 11:10 AM
I've nbeen told the bellhousing is different between the Stanza/Altima and the Maxima. I can't say for sure that it is true but that's what I heard once.
Oct 19, 2002 | 11:13 AM
Re: thanks
why don't you call and find out?
Oct 19, 2002 | 01:33 PM
Re: Re: thanks
HMMM If the KA24DE Tranny fits a maxima than the KA24DE should fit
Oct 19, 2002 | 05:18 PM
minus the motor mounts
Oct 20, 2002 | 12:20 PM
Based on assumption, I would think the bellhousing would be quite different..4cyl to V-6. But I never heard that the 240 and the 300z shared bellhousings. If this is true, then the same probably goes for the stanza to max interchange.
Oct 20, 2002 | 12:27 PM
This is off of www.drivetrain.com
Car: Year: # of Gears: Type of Tranny
240sx 1989-96 5 FS5W71C
300zx (n/a) 1984-89 5 FS5W71C
I'll go take a look at my brother's 95 240 today and see if i can notice some similarities (which i hope there are)
Oct 20, 2002 | 04:12 PM
my brother's car is too low to tell. i put it up on ramps and couldn't get under there so i'll find another way to check it out or run to a junk yard to see if they have any ka's laying around.
Oct 20, 2002 | 08:56 PM
confirmation from ebay auctioneer
I just received an email from Phoenix Hard Parts the company that sells rebuilt trannyies saying that yes the 89-94 stanza and maxima transmission are compatible with no modifications.
Oct 20, 2002 | 09:30 PM
sweet!! that means good things for me.
Oct 21, 2002 | 05:28 AM
That's cool, really opens up the possibilities of finding reasonable cores or replacements.
Oct 21, 2002 | 06:05 AM
OK, I posted the KA24 to vg30 tranny interchange on www.z31.com One reputable member there claims that this is "completely bull****" He says he knows from first hand experience. This makes sense to me, as a 4 cyl block and V6 are no where near the same dimensions.
Oct 21, 2002 | 06:22 AM
Are you sure that site is right because it says the 92-96 maxima has the same tranny...
Oct 21, 2002 | 06:34 AM
Quote:
Same tranny as what?
