Rear Brakes
Old Oct 19, 2002 | 11:42 AM
onegoode's Avatar
Rear Brakes
I am trying to put rear brake pads on my 92 SE.How do you get the piston to retract so that the new pads will fit?On all the brakes i've put on before I simply used a "C" clamp to push it back but these won't go in.Is their a secret to the rear maxima brakes that I don't know about?Thanks
Old Oct 19, 2002 | 01:04 PM
«§»Craig B«§»'s Avatar
Re: Rear Brakes
yes there is and it's been posted MANY times before, please try a search next time
you have to twist it clockwise. There are special tools to use for this or just use needle-nose pliers but be careful not to damage the boot
Old Oct 20, 2002 | 02:15 PM
onegoode's Avatar
Re: Re: Rear Brakes
you have to twist it counterclockwise. There are special tools to use for this or just use needle-nose pliers but be careful not to damage the boot
Thanks for the information.I did the brakes with no problem this morning except for one thing.You turn the piston clockwise instead of counterclockwise.I turned the first one counterclockwise until it fell out so I had to bleed the brakes.I used a small about of brake fluid to lubricate the piston and boot and i just used plain channel locks to turn it.Thanks again for the info. it saved me a big headache.
Old Oct 20, 2002 | 06:51 PM
Re: Re: Re: Rear Brakes
oh crap, I'm sorry about that; you are right it is clockwise
glad you got everything worked out all right
Old Oct 20, 2002 | 09:30 PM
onegoode's Avatar
Re: Re: Re: Re: Rear Brakes
By the way I did a search and thats how I found out about using brake fluid to lubricate the boot and piston.The reason I didn't do one the first time is because as many times as I have used maxima.org i didn't know about the search until you pointed it out.I'll know next time i have a problem.
Old Oct 21, 2002 | 06:14 AM
Re: Re: Re: Re: Re: Rear Brakes
no problem
now you know and knowing is half the battle
welcome
Old Oct 21, 2002 | 06:16 AM
nubiannupe's Avatar
OG Maxima.org Member
Re: Re: Re: Re: Re: Re: Rear Brakes
no problem
welcome
Thanks, GI Joe!
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
