senser and poor milage or sumthin'?
Old Dec 24, 2000 | 04:39 PM
MaximaBella's Avatar
Ive been listening to you all talk about this 02 sensor or sumthin...and getting better gas milage, I seem to be getting bad milage, I used to get like 400 to a tank, now I just filled up like, 2 days ago, Im about at 1/2 a tank, ( I have been pushing her a little more than shes used to, I have been influenced) But Im at 1/2 tank, and Ive gone like 100 miles, thats a joke, whats the deal here?
Old Dec 24, 2000 | 04:58 PM
NYCe MaXiMa's Avatar
umm...
O2 sensor can definately cause low gas milage, but it isn't the only thing. I thought that was it in my case and changed it, now I am still getting around the same as I used to, which is like 11 mpg. I will be lucky to reach 200 miles on a full tank. Fuel filter, sparks, distributor cap, rotor... etc.. Basic tune up things can cause low gas milage. I have replaced most of them and it still sucks ***. My next thing will be to check my distributor cap, rotor, replace wires and then if it still drinks gas I'll go to Nissan and have them run a diagnosis test when they hook it up to a computer. Everyone suggests that they WILL find the problem. Before replacing the o2 sensor make certain that is your problem.
Old Dec 24, 2000 | 06:59 PM
Foo90SE
Yeah the o2 sensor for the 90' SE (the VG motor) is like 100 bucks cheapest one i can find..i did all the tests i could to make sure mine was bad and turns out it is..but im not getting that bad gas milage i dont think.
Old Dec 24, 2000 | 09:00 PM
NYC GS4's Avatar
Question for foo90se
Did you unplug it and then drive? Try to mention all of the things I should look for when I do that. Thanks.
Old Dec 24, 2000 | 09:22 PM
Foo90SE
i tried the unplug technique...i checked the signal with a voltmeter and a oscilliscope(sp?) too. all pointed to a bad 02 to test with a voltmeter u check voltage at the white wire from the 02 sensor with it plugged in and car warmed up. voltage should change from like .1 to 1 volt
mine was stuck at .2 or so...
Old Dec 26, 2000 | 09:26 PM
I think Im losing it, now it looks much better, I think the first half always goes so fast, but my man brought sumthin to my attention, hes like stop pushing on the gas pedal in the morning ( I do that thinking Im getting the fuel up in my lines or sumthin, I think either my starter or fuel injector is going, I know its one or the other) I do stupid things sometimes, well I stopped pressing the gas, and I think its getting better, he he, boy I feel dumb.
Old Dec 26, 2000 | 09:29 PM
Foo90SE
Yeah if you were pumping the gas pedal while starting the car...thats not good fuel injected cars like ours are ment to start w/o pressing the gas.
msellas
Sep 23, 2015 09:16 PM
hydriplex
Aug 28, 2015 02:13 PM
Quickgtp
Aug 27, 2015 02:13 PM
delerium75
Aug 19, 2015 11:08 AM
Viralkill
Aug 16, 2015 05:09 PM
