Help with Heater
Old Oct 26, 2002 | 06:12 PM
zondy's Avatar
Help with Heater
Recently.. i Cant get my heater to work..When i switch the temp control ( which is kinda stuck).. Sometimes its really hard to switch it to the heat side..and when i finally do..it still dosent work
Plz help
thanks
Old Oct 26, 2002 | 10:39 PM
Engloid's Avatar
mine was the same way...it was hard to move it either way. It was the actual lever mechanism just inside the front panel. There is the part you can touch from outside that slides straight across, but it moves a lever inside that has a pivot point. The slide part had worn out and didn't want to move easily, as the "track" it slides on had broken free. Since it's molded plastic, there was no fix but to find junk yard parts.
My maxima is a beater...wrecked, dirty and not worthy of much repairs anymore...
so I pulled out the sliding part and now stick a screwdriver in to move the lever back and forth. It actually will go farther to each side this way so you get a hotter heat.
Old Oct 26, 2002 | 10:57 PM
nubiannupe's Avatar
OG Maxima.org Member
"...a hotter heat"
There's something you don't hear every day!
howardis
Dec 11, 2019 06:10 PM
dr3am
25
Oct 22, 2015 08:53 PM
RWCreative
Sep 21, 2015 11:01 AM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 7, 2015 04:20 PM
