4th gen springs on 3rd gen???
Old Nov 2, 2002 | 05:55 PM
MaDMaX024's Avatar
is this even a little possible? what needs to be done to get them to work?
Old Nov 2, 2002 | 10:40 PM
dmontzsta's Avatar
Ford Only.
3rd gen = IRS
4th gen = Beam
I beleive the 4th gen has rear shocks and we have rear struts...so NO!
Old Nov 2, 2002 | 11:35 PM
MaDMaX024's Avatar
Originally posted by dmontzmax
3rd gen = IRS
4th gen = Beam
someone mentioned altima springs on a 3rd gen...any ideas?
also, i dont think it would make any difference which setup (irs or beam) the car has, so long as the springs will mount to the perches, spring rates and what not can be compensated for if need be.
Old Nov 2, 2002 | 11:40 PM
dmontzsta's Avatar
Ford Only.
the 3rd gen rear struts are much longer than the 4th gens, therefore you would have longer springs...altima's I dont know, but I do know that Struts and Springs are not the type of thing to just play with, they are a PITA and if you are having someone do this you are going to pay and if you are going to do it, the chances are your car will be down for some time and good luck finding the right spring and not wasting your time and money, what is wrong with the 3rd gens springs? Intrax/Eibach/Sprint/Suspension Tech.
Old Nov 2, 2002 | 11:56 PM
D-sta's Avatar
I guess some people have too much time on their hands. Just buy stuff that is made for our cars and not waste your time and money.
Old Nov 3, 2002 | 06:50 AM
nubiannupe's Avatar
OG Maxima.org Member
Kinda like the BMW headlight thing, huh?
Old Nov 3, 2002 | 08:09 AM
tilt's Avatar
The springs will probably fit, but the ride height of the front and back will probably be messed up. Plus the spring rates will be different so it may handle like crap.
Old Nov 3, 2002 | 08:32 AM
MaDMaX024's Avatar
i want coilovers is basically what it boils down to.
Old Nov 3, 2002 | 08:38 AM
Sudesh's Avatar
Altima and Stanza front suspensions will bolt onto the maxima without a problem. Since the Altima and Stanza front suspension is shorter than the maxima's, they'll even have an added bonus of lowering the front of the maxima, but with stock comfort. The Altima springs are as wide as the maxima springs, the stanza springs are a little more 'skinny'. I wouldn't use stanza parts because they're aren't any performance front struts for stanzas.
If you guys use maxima lowering springs on altima struts, it might be best because the strut itself is shorter. I don't know if maxima springs will 'fit' onto altima struts perfectly though.
You guys can look into it if you want. Go to a junkyard.
Old Nov 3, 2002 | 08:39 AM
MaDMaX024's Avatar
which springs?
Old Nov 3, 2002 | 08:45 AM
MaDMaX024's Avatar
what about rear? if the springs will work on the maxima, then if i were to get an altima rear cartridge, then it would should work with the maxima housing as i wouldnt want to change the brakes and whatever else is back there that may be different. i love how some things can be frankensteined.
Old Nov 3, 2002 | 09:03 AM
dmontzsta's Avatar
Ford Only.
Well you guys have fun trying to adapt $400 suspension to your car, and when it is all said and done, your car will not handle much different than someone that put some Tockico/Eibach's on.
Old Nov 3, 2002 | 09:07 AM
Sudesh's Avatar
Go to a junk yard and find out the rest. I'm not going to provide you with every ounce of information you need. I've discussed the relationship of the stanza and maxima before.
Old Nov 3, 2002 | 09:09 AM
MaDMaX024's Avatar
thanks for the encouragement. i'm not looking for handling, if i were, i'd get koni's and eibachs. i'm satisfied with the way my car handles now (but i will add sways and SFC's when i take it apart again..when its warmer than 25*), the purpose of coilovers, for me, is to have ride height adjustability. with shortened struts, i could go lower and still have a good ride. i wouldnt get bags because they probably take away from the handling, and besides, i have better things to spend $2500+ on.
Old Nov 3, 2002 | 09:13 AM
MaDMaX024's Avatar
i understand that you've discussed it before, but from what you've said in this thread, you've discussed how the front will bolt up and thats only half the battle.
if you know the answer to my question, why not tell me? if you've said it in another thread, i dont get offended when you tell me to search. alot of times, i dont ask people to repeat themselves unless they've answered the same question more than once and the answers arent consistant with eachother.
Old Nov 3, 2002 | 09:14 AM
dmontzsta's Avatar
Ford Only.
I am trying to save you some hassle. Have you ever taken apart the rears on a 3rd gen? not fun at all...I would just pic a spring you like the drop on and get it, I chose Intrax it is perfect and the wheel gap is nice, those 4th gens were having a hard time in the twisties with me when I was stock, now with SFC's, FSTB and Intrax/Kyb, I think they are in trouble. I personally wouldnt try it dude...it is going to be a PITA and dont coilovers cost $1000?
Old Nov 3, 2002 | 09:18 AM
MaDMaX024's Avatar
i have replaced all my springs and struts. it wasnt difficult at all except lining up the top mount to the rest, but it really wasnt that bad as my STs didnt need to be compressed to get the top mount on in the rear.
for coilovers, i'm talking about ground controls, arospeed, weapon R..whatever the cheap ones, not the 15way JICs or cattmans..
Old Nov 3, 2002 | 09:33 AM
dmontzsta's Avatar
Ford Only.
Well let us know how it works...
MaDMaX024's Avatar
i will if i find out if the altima rears will work on the max.
Old Nov 3, 2002 | 09:38 AM
Sudesh's Avatar
http://forums.maxima.org/showthread....ghlight=stanza
Old Nov 3, 2002 | 09:58 AM
MaDMaX024's Avatar
so what you said in that thread is the stanza rears will defiantly work. now i'm wondering, stanza ground controls, altima struts (as they are shorter and dont they have adjustable strut options that're cheaper than koni? illumina, AGX..??). i'm not looking to slam my car to the ground so the parallel links and massive negative camber wont be a problem, i just want to go from say sprint height to eibach height, and i want it all even unlike my f/r gaps w/STs.
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
